Old 08-24-2021, 07:24 PM
md9680 md9680 is offline
Default Best way to remove bow from part
For some reason, one set of E-903 Outboard and E-904 Inboard Tip ribs were already fluted by someone when it was time to work with them. They appeared serviceable and, yes, one set went together well. However, the E-904 for the second set has a bow in the web which prevents it from making full contact with its E-904 counterpart, leaving a sizable gap at the edges when clecoed.
What's the best way to remove that bow?
Thanks.
Mike Davisson
Edgewood, NM
Cherokee 235
RV-14A #140805
VS complete
Rudder complete
HS complete
Elevators in progress
2021 =VAF= Donor
Old 08-24-2021, 07:42 PM
Taltruda Taltruda is offline
You can unflute two ways.. use the flat seamers and just squeeze lightly, don’t flatten it all the way out, or you can also carefully use the fluting plyers backwards and just take out a little of the hump without making it go the wrong way
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 08-24-2021, 11:33 PM
Thanks, Taltruda, but it currently sits perfectly flat on a truly flat surface, so "unfluting" doesn't appear to be required.
But the top web portions of both the E-903 and E-904 ribs have to be flat enough to be riveted to each other (see page 09-02, Figure 4). This can't happen because the E-904 rib has a longitudinal upward bow that prevents it from laying on the E-903 without rocking around like a cooking pan that rocks on the kitchen counter because it took a 30-year beating from someone with a potato masher.
I need to flatten the web of the rib inward without causing damage. The radius of the flange-to-web bend appears to have been significantly decreased in the process of bending the flanges to establish the required 90-degree angle, resulting in the outward/upward bowing of the rib's web. Maybe use some scrap lumber and a mallet to reshape the web?
There. Might have answered my own question. I'll deal with it tomorrow.
Thanks, again, for your thoughts.
Mike Davisson
Edgewood, NM
Cherokee 235
RV-14A #140805
VS complete
Rudder complete
HS complete
2021 =VAF= Donor
Old 08-25-2021, 05:51 AM
mturnerb mturnerb is offline
Forming ribs usually causes bowing in such a way that fluting between rivet holes on the flanges should flatten the web. I ended up fluting the E-904 ribs to fit. IIRC E-903's came fluted but I adjusted a little for perfect fit.
Example:
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
Old 08-25-2021, 07:05 AM
Oh I think I understand what you need now.. ok how about using a bean bag or perhaps a thin carpet at support and a 1x1 piece of wood and a hammer to gently pop out the warping? Remember this isn’t rocket surgery here..
Tom
Las Vegas
RV-4 flying…
Old 08-25-2021, 07:25 AM
If only the web is bowed this makes sense. I wonder if flattening the web would cause reactive bowing of flanges.
Turner Billingsley
Old 08-25-2021, 07:35 AM
NavyS3BNFO NavyS3BNFO is offline
If I understand your issue correctly, you could use a couple C-clamps to clamp the webs together tightly and then rivet them. Once you have a couple rivets in, you can probably remove the clamps or readjust them as you go to keep the webs squeezed tightly together.
I've found that spring clecos sometimes don't have enough clamping force. There are also cleco clamps and draw type wingnut clecos that provide more clamping force.
RV-8 empennage DONE
Wings 99% done
Fuselage in progress
Old 08-25-2021, 08:21 AM
Originally Posted by mturnerb View Post
...I wonder if flattening the web would cause reactive bowing of flanges.
I figure it will but I have the tools to fix that.
Mike Davisson
Edgewood, NM
Cherokee 235
RV-14A #140805
VS complete
Rudder complete
HS complete
2021 =VAF= Donor
Old 08-25-2021, 08:28 AM
Originally Posted by NavyS3BNFO View Post
...C-clamps to clamp the webs together tightly and then rivet them...spring clecos sometimes don't have enough clamping force...
I like your idea of the C-clamps. I guess it didn't occur to me because, at the time, I was counting on the clecos pulling everything together but, as you say, they don't have enough force. Thanks.
Mike Davisson
Edgewood, NM
Cherokee 235
RV-14A #140805
VS complete
Rudder complete
HS complete
2021 =VAF= Donor
Old 08-26-2021, 09:15 AM
Well, guys, I managed to use the E-913 Counterbalance Skin to basically "force" the bow out. It took some doing to cleco, but it's now ready for future riveting.
Mike Davisson
Edgewood, NM
Cherokee 235
RV-14A #140805
VS complete
Rudder complete
HS complete
2021 =VAF= Donor
