Go Back   VAF Forums > Model Specific > RV-14
Old 08-07-2020, 12:27 PM
rjarrell's Avatar
rjarrell rjarrell is offline
Default ZipTips Premiere Winglet Ė Vanís RV10-RV14
Need help/answers with my winglet installation for RV-14 build. Using the W-00026 (aileron neutral position template), from RV-14 plans 23-10 4/15/19 rev. 0, my tips come out 1/2 below the aileron. verified the template with my RV-10 built in 2014 and the manufacturing hole location. Also pulled a wingtip and it fits in the -14 wing or would with very little adjustment. FYI I have spoken to Damien at Aveo, Kevin at Vans (build assist) and previously added to another thread with no response.
Damien says he has sent out over 50 of these (not sure if they were -10 or -14's or the count of each) and has heard no complaints. Van's has no idea what going on but was very nice and would be interested is an answer also. All I see posted are pics of opening the boxes containing these tips no actual installations.
Any help, pics recommendation would be greatly appreciated (I'm married so don't worry about seeing a mistake I made and hurting my feelings). Thanks in advance.
ZipTip more than 1/2" off
Right ZipTip with W-00026 in place
Right wingtip
Right wingtip bottom
Right straight edge
Left wingtip
Left with W-00026
Comparing RV-10 (blue) and RV-14 (white) ZipTips
RV-10 ZipTip matched to RV-14 wing
Bracket on RV-10
[IMG]
Rodney RV-10 "LIBERTY"
building RV-14 "FREEDOM" 2020
Dues paid 2021
Old 08-07-2020, 12:45 PM
scsmith scsmith is offline
I don't really know if this helps, but just a thought:
The RV-10 and RV-14 airfoil is designed to have the flaps and ailerons rigged to cruise with some negative (trailing edge up) deflection. Is it possible that the tips were not made to include that reflex in the aileron rig position?
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 08-07-2020, 01:12 PM
Got any photos of the winglets? (Not wingtips but winglets).
Reason I'm asking is that winglets usually increase the wing's bending moment, and generally aftermarket winglets may or may not factor that in, either by changing the operating limitations or by selective reinforcement or other means.
Sometimes they affect the flutter speed, too.... winglets can offer some advantages but might also have negatives.
Dave
Old 08-07-2020, 01:52 PM
MED MED is offline
Looks to me like the new wingtip is below the aileron. Looks like a reflection from the other wing in a wing stand.
MED
140236
N435MD
Miss March 2020
Old 08-07-2020, 02:42 PM
Tom Martin Tom Martin is offline
Wait until the wings are on the airplane and the flaps and ailerons are mounted in fight mode, with the elevator fixed in the trail position.
I found that the template got close to the right position but the linkage needed some final adjustments. Then you can mount the tips to see if you really do have a problem
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 08-07-2020, 03:20 PM
rjarrell's Avatar
Awesome, this is kinda where I'm at right now. I can split the glass at the end right up to the rear position strobe light and adjust it. Just hoping there was a better way. Thanks for your reply. Rodney
Dues paid 2021
Old 08-07-2020, 04:57 PM
sjarrell sjarrell is offline
Does anyone have any pictures of their wings finished with the new "winglet" ZipTips that shows them fitting properly?
Thanks!
Steve Jarrell
Building RV-14A QB "Freedom"
N614US (June 14 - Flag Day)
Dues Paid - Gladly!
Old 08-07-2020, 08:21 PM
Dave
I'm not sure what any of that would have to do with the alignment of the straight part of wingtip with the aileron as shown in any of the photos, but if you want to see the curved part of the Aveo Premier ZipTip (not the straight part in question) look at the photos on Aveo's site here.
Steve Jarrell
Dues Paid - Gladly!
Old 08-07-2020, 08:51 PM
I understand completely, but our question is regarding the fitment of the Aveo Premier ZipTips to the wings, not the aerodynamics of them.
Thanks!
Steve Jarrell
Dues Paid - Gladly!
Old 08-09-2020, 04:24 PM
I think that is correct. The aileron is reflexed up, and it looks like the wingtip was made for a zero-reflex position of the aileron.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
Hobbs 700
also
