Go Back   VAF Forums > Model Specific > RV-14
  #181
Old 07-05-2021, 08:23 PM
Dennis Harm Dennis Harm is offline
Click image for larger version
ID:	13345moved the planed to the airport now for the assembly
Old 07-06-2021, 08:16 PM
bk1bennett's Avatar
bk1bennett bk1bennett is offline
Originally Posted by Dennis Harm View Post
Attachment 13345moved the planed to the airport now for the assembly
Congrats!
Well done
Latest Donation Dates: 06 August 2020 & Dec 2020
RV-14A Empennage Kit #140396
Old 07-09-2021, 05:37 AM
jeffreyuh60's Avatar
jeffreyuh60 jeffreyuh60 is offline
She’s looking great, Dennis! Let me know if you need help hanging the wings. I need to poke around your bird to see how you wired a few items. I will be starting on the FAA paperwork this week.
JT
Jeffrey Turner
RV-14 N39JT
Almost up to smoke test and first start...
Old 09-03-2021, 03:58 PM
Default Prop governor spring?
Med,
What, exactly, did Hartzell tell you about the governor spring? I told them of the same issue, but they gave me no advice, or solution.
BTW, the -241 label denotes the TB engine with the particular magneto arrangement I ordered.
JT
Jeffrey Turner
RV-14 N39JT
Old 09-03-2021, 05:16 PM
MED MED is offline
Originally Posted by jeffreyuh60 View Post
Med,
JT
Just ask them if they will install a weaker spring, because you are experiencing prop control creep. They may just send you a weaker spring and let you install it. They were aware of the issue, so it should not be a problem.
MED
140236
N435MD
Miss March 2020
Old 09-04-2021, 06:56 AM
I asked for exactly that. Whom ever I spoke with stated that they would not do that. Perhaps I will have to call again and hope to get the same person you spoke with. They did sell me a longer governor control arm which works perfectly with the RV-10 control quadrant I installed.
JT
Jeffrey Turner
RV-14 N39JT
Old 09-15-2021, 09:39 AM
PatMac PatMac is offline
Originally Posted by N667CD View Post
SB, 14 months from 1st rivet to AWC.
Man oh man...impressive. Congrats I'd love to pick your brain as Im just getting started on my 14A
