Old 08-28-2021, 08:21 PM
LR60 LR60 is offline
Default Exhaust Leak
Both exhaust joints have some blow by, any suggestions on how to prevent this. The alignment during initial install was not great and now after 10 hours Iím seeing this..used nickel anti seize during install.
ID:	15161  Click image for larger version
Mark
RV-14 (flying since 8-11-21)
SN-140458
Old 08-29-2021, 06:21 AM
ShortSnorter ShortSnorter is offline
Are those bolts too long - as in are the nuts out of thread to continue tightening?
Ryan
RV-14 In-Progress
Build Site
Old 08-29-2021, 09:54 AM
The correct hardware is installed. Instructions are to run the nuts down to the bottom of the threads. The springs set the determined tension on the clamps.
The mother ship suggested rotating the clamps and re clamping, which I tried but it did not help.
The second suggestion from vans was to apply a sealant. Iím curious if there is a better way to align the joints before trying high temp sealant.
Mark
SN-140458
Old 08-29-2021, 10:31 AM
Walt's Avatar
Walt Walt is offline
The ball joints should not leak like that, I would take them apart and see what's going on.
Leaking exhaust is a serious problem, if you don't have a CO detector you should probably install one.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 08-29-2021, 01:36 PM
Walt's Avatar
A Recommendation from Vetterman (the 'man'):
"my summation is the the springs are too light or not strong enough because as they heat up they lose tension and a separation is likely the cause unless there is a deformation of the ball joint. I suggest the the guy call Clint and get the proper springs and bolts even though itís not his system. Just my input."
Larry Vetterman
Old 08-29-2021, 05:31 PM
Thanks for the advice Walt.
I do have an GD-40 CO detector installed.
Iím gonna drop the tailpipe and see if I can improve the alignment and play around with the spring tensions per your advice.
Thanks again
Mark
Mark
SN-140458
