Old 08-24-2021, 06:43 PM
SabreFlyr SabreFlyr is offline
Default Straightening curved fresh air vents
After trimming the forward 3/4" of one of my fresh air vents per page 29-21, I still have a substantial curve that takes significant force to flatten. I'm concerned that, even with a good adhesive, it might still pry itself free at the forward end. I'm considering clamping it to the top of my workbench while using a hot air gun (Steinel; capable of somewhere north of 800°F) to soften the plastic. Any reason not to try this? Secondly, how much heat should I consider?
ID:	15051  Click image for larger version
Ray Dosh
LJ45 driver
RV-14 #140212
Empennage completed
QB wings 95% done
QB fuse in progress
2021 DUES PAID
Marion, IN MZZ
Old 08-24-2021, 07:41 PM
VA Maule VA Maule is offline
Gently warm it with a heat gun a little at a time until it's plastic (verb) enough to take a new set . Let it cool against flat surface , in a few minutes it aught to be good to go.
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 08-24-2021, 08:06 PM
Taltruda Taltruda is offline
800 degrees is too much. Harbor freight sells a cheap heat gun, but you might have luck with a blow drier too
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 08-25-2021, 04:58 AM
I should have added that it is fully adjustable. I'll definitely start on the lower end of its range.
Ray Dosh
LJ45 driver
RV-14 #140212
Empennage completed
QB wings 95% done
QB fuse in progress
2021 DUES PAID
Marion, IN MZZ
Old 08-25-2021, 04:00 PM
abwaldal@gmail.com abwaldal@gmail.com is offline
You have probably seen 2 and 3" conduit used in electrical work. We use a brush burner torch and heat that big thick stuff slowly and when it is in a plastic state just bend it to where we want. 90 degrees, around corners, you name it it goes.
Plastic is very malleable if you take care
Heat away. Art
Old 08-25-2021, 05:24 PM
emsvitil's Avatar
emsvitil emsvitil is offline
Would hot (boiling?) water pot do the trick?
Ed
