Old 03-17-2021, 01:46 PM
Rx7thHeaven Rx7thHeaven is offline
Default Pneumatic Squeezer yoke question
Question for the more experienced builders... I am about to purchase a pneumatic squeezer to help with my -10 build. I am currently working on the tail kit. I will probably be buying a re-built unit (unless a fair deal comes up on the forums or ebay) and I can choose which yoke comes with it. So my question is, working on the tail kit and moving to the wings, which yoke is best suited? I will be buying aditional yokes down the line as needed, but figured I would start with one thats universal and I can get the most immediate use out of. (Price of the yokes is irrelevant as the squeezer price will change depending on the yoke).
Thanks!
Jonathan
RV-8 Driver
RV-10 Build in progress
Old 03-17-2021, 02:28 PM
Desert Rat Desert Rat is offline
Longeron yoke.
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 03-17-2021, 04:36 PM
BryanG BryanG is offline
Im only through the vert stab and the rudder but I have used a standard 3 yoke the most, then a 4 tight squeeze yoke, and a few times the longeron yoke. I would buy those three again in a heartbeat. If I could only have two it would probably be the longeron and the tight squeeze yoke. Only one Id probably go with the longeron but I would save for the tight squeeze pretty quick.
-Bryan
Old 03-17-2021, 04:40 PM
DanNiendorff DanNiendorff is offline
Default Like golf clubs.....
Yokes work out little bit like golf clubs...... one for every situation. Hard to play the whole game with just one.... as it looks like you are aware.
But the one that lives on my squeezer most of the time is the longeron yoke.
RV-14A 140658 Empennage in progress
Zenith CH801 - old school pre-CNC era kit - flying
Zenair 2500A amphib floats - From basic parts kit - 80%
Dues 2021 ✅
Old 03-17-2021, 06:40 PM
wirejock's Avatar
wirejock wirejock is online now
Default Longeron
Longeron if I had to use.one but prefer the smallest one that fits the job. Less flex, better shop heads. You also would benefit from the adjustable ram and quick change pins.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 03-17-2021, 08:30 PM
No_0ne No_0ne is offline
The two I use most are the 3" and the longeron. The 4" no-hole is nice to have when you are in tight places, but seldom used (at least by me). As Larry said, make sure you get the adjustable ram and quick change pins as well.
Old 03-17-2021, 11:19 PM
rongawer rongawer is offline
https://www.flyboyaccessories.com/product-p/2701.htm
If you haven’t bought the squeezer yet, I highly recommend the Numatx. Just get it; you’ll thank me later.
And then I agree, the only two you really need are the longeron and a 3” yoke. I have others, but these are the only two I actually use. I find for anything else, It’s generally easier to just use a rivet gun and bucking bar.
Ron Gawer
- RV10, N762G, Build in progress.
- Several others that are now just great memories for me.
Old 03-18-2021, 07:53 AM
hillc95 hillc95 is offline
3" and longeron for me
Chris
N654CH reserved
n654ch.blogspot.com
Old 03-18-2021, 08:20 AM
RV10Pilot RV10Pilot is offline
Default Longeron
Agreement? Wow we never seem to agree. The question must have been too easy.
If I could only have one yoke it would be a Longeron.
Old 03-19-2021, 07:59 AM
Thank you everyone for the input. I know I will need an assortment of yokes, Just trying to decide which 1 or 2 should be first on my list. Looking like 3" and longeron are the first 2 I should get
RV-8 Driver
