Go Back   VAF Forums > Model Specific > RV-14
Old 05-12-2015, 03:44 PM
Gahannaflyer Gahannaflyer is offline
Default Baggage compartment side covers sound deadening
I am about to install the baggage compartment flooring and side covers, and am wondering if anyone has put any sound deadening in behind the panels or other places. Obviously it cannot be added easily latter. Is anyone putting in any insulation in the cockpit? Or other places? I am concerned about added weight.
Steve
Old 05-12-2015, 04:25 PM
jerry sparks jerry sparks is offline
Default insulation
Try this info@harboursupply.net
Old 05-12-2015, 07:27 PM
sglynn's Avatar
sglynn sglynn is offline
Default Sound
Yes I put sound DAMPING material on floor and sound ABSORBING material also. There is no such thing as dampening.
Steve Lynn
Built RV-7A
Flying It
Anacortes, WA
www.mykitlog.com/sglynn
Old 05-12-2015, 08:08 PM
rleffler's Avatar
rleffler rleffler is offline
Steve,
Many RV-10s have done what you described. The sides and floor of mine are insulated. It greatly helps with noise reduction. There are some materials that work better than others. Give me a call if you want to discuss.
Bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 05-12-2015, 08:32 PM
N15JB N15JB is offline
Not exactly true; I got dampened just today when I got caught in the rain.
Re the OP's question, like Bob I put sound absorbing material behind every panel from firewall to baggage bulkhead. It does make the plane noticeably quieter(and heavier), but in retrospect I would not do it again. If you value your hearing, the cabin is still far too noisy to fly without good anr headsets.
I recommend leaving out sound absorbing/damping material and enjoy the weight savings.
Jim Berry
RV-10
Old 05-13-2015, 05:27 AM
curtis's Avatar
curtis curtis is offline
I agree with Jim, leave out the weight and just buy a good headset. I believe that you will never get the sound level down to a level where you can fly comfortably without headsets.
RV-6A Slider
550 hours +
Build it light and cheap
