Old 01-29-2015, 05:23 AM
sabswbc sabswbc is offline
Tom, when you put the halves together, did you have any trouble. The plans call for leaving the last 8 rivets out until the two are mated. Since only the last two are common, i assume they feel you will need to pull the skins back to join the two.
Is it just me, or is everyone wondering how the gear and step will attach. not much room in those areas.
I am finishing the brakes, flaps, fuel lines, and flight controls this week and plan on doing the front fuselage section next.
I am air conditioning the plane and will run the hoses and mount the scoop before joining the halves.
Sam Butler
RV14
RV 12
RV 7A
RV 10
RV 7
Old 01-29-2015, 05:35 AM
Tom Martin Tom Martin is offline
No problems, it was a non event. I use two picnic tables and did the job by myself. Slide the tables together with a couple of feet between them and then slide the respective halves together. I raised and lowered the front of the fuse and the back of the tail until the bottom skins lined up, put a few clecoes in and then raised the tail until the sides lined up, half an hour at the most. Using the picnic tables allows for a nice open area below the two halves for riveting.
Today I will start the riveting process doing as much as I can by myself before calling on my rivet buddies.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
Old 01-29-2015, 07:24 AM
jerry sparks jerry sparks is offline
Default status report
congratulations. This must be a big day seeing the final parts come together. Jerry
Old 01-29-2015, 01:46 PM
dave4754's Avatar
dave4754 dave4754 is offline
Default Love seeing that Canuck Banner on the wall
My plane is getting along as well but the new -14 looks great! loved the Canada plug in the background
Dave Cobb
[color="Red"]=VAF=2019 Donation - and a bit extra for great work![/COLOR="blue"]
Empennage RV 7 - Tipper
Wings complete
Dynon installed and running
Fuse closer to completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
