I scuff with Maroon Sctochbrite pad, clean with some soap and water, let dry in the Houston sun, then use SW GBP self etch out of the rattle can.
Does anything truly DRY in HOUSTON?
Mr Dye,
Do you clean the scuffed parts after you have scuffed them or do you go right from scuffing to using Duplicolor primer? I just bought 2 cans of Duplicolor (all they had left) but haven't used any yet. It;s on sale right now 2 for 1 Think I'll buy a case of it!
Cheers
Chris
everyone's input. My reason for asking was related to the alclad layer. I know it's VERY thin, and I know it's possible to scuff off or through. I also have to believe that paint adhesion to a scuffed surface will be better. So far I have just cleaned and primed with NAPA 7220.
I would be great to hear from someone who has some real expertise in all this
To scuff or not to scuff... that is the question.
