Old 03-23-2020, 11:37 AM
RhinoDrvr RhinoDrvr is offline
Default RV-8 Tailwheel Steering Geometry
I recently found quite a bit of wear in my Aviation Products tailwheel attach block with 1500 hours on it. This is allowing the fork a fair amount of fore and aft motion that I?d like to stop.
I called Karen and ordered the parts. My airplane currently has a 20 degree attach block installed (see photo attached) but this puts the top of the steering shaft forward of the fork...which I gather is less than ideal. I don?t get any tailwheel shimmy, but I can feel the wheel spinning around the instant I set the tail down until I get some weight on it.
API also offers a 10 degree unit, which would put the steering closer to the correct geometry, but I understand will make steering stiffer...I?m concerned about added wear to the steering system if that is the case.
What angle API blocks are you guys running with your chain setups?
https://photos.app.goo.gl/rzkZ1fGzNB62PX6e9
Evan Levesque
RV-8 N88MJ (Built by Michael Robbins)
Lemoore, CA
Old 03-23-2020, 11:44 AM
smithflys23 smithflys23 is offline
I?m interested to hear the responses you get.
My tail wheel sometimes spins when I set it down.
Old 03-23-2020, 11:53 AM
scsmith scsmith is offline
How can it spin around? Isn't it locked with the pin to the steering arm?
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 635
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 03-23-2020, 12:59 PM
I have an API fork that was made to fit into a standard Van's 'yoke'. (I think we need a better name for that part, like 'attach block').
Works just like a Bell fork.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
Hobbs 635
Old 03-23-2020, 01:16 PM
Maybe it?s not spinning all the way around, but there?s some definite feedback in the pedals that it?s not tracking straight at touchdown.
What is the geometry of your setup, Steve? Does the pivot shaft point forward or aft? Most RV?s I?ve seen have the top forward of the bottom, but from what I gather that is incorrect.
Evan Levesque
Lemoore, CA
Old 03-23-2020, 01:41 PM
The top is slightly forward of the bottom. Standard Vans attachment block.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
Hobbs 635
Old 03-23-2020, 02:08 PM
skylor's Avatar
skylor skylor is online now
Default Gooseneck
I have it on good authority that Van's internally refers to this part as the "po+ pipe" .
Skylor
Old 03-23-2020, 03:45 PM
Bicyclops Bicyclops is offline
I did a lot of work on a one-off motorglider that had the vertical pivot shaft of the tailwheel yoke mounted parallel to the aft bulkhead of the fuselage. It is a castoring setup with no steering links. With the tail down on the ground the shaft pointed forward about ten degrees. The wheel wanted to do anything but follow the airplane and, once it spun around and got the tailwheel forward of the post, it sat down an inch or so. That made it very difficult to get it back pointed the right direction. We went through a set of brake pads trying to figure it out before first flight. I finally remounted it to be pretty much exactly vertical with the wheel on the ground and it turned into a pussycat and very well mannered. I get it that the shaft past vertical aft isn't ideal, but whatever you do, don't go past vertical forward trying to fix it.
Ed Holyoke
Old 03-23-2020, 06:22 PM
Carl, I'm not convinced this is correct.
Both forward tip and aft tip have positive castor "trail" --wheel contact patch behind steering axis creates a restoring moment when yawed.
In addition to the amount of trail, there is also the effect of potential energy.
With the top of the axis tipped forward, the weight wants to make the wheel point straight aft. Any yaw deflection lifts the tail higher, so there is additional restoring moment trying to straighten the tail.
With the top of the axis tipped aft, the weight wants to make the wheel turn. It is happiest when turned 180 degrees, because that is the lowest height. So this vertical displacement effect is de-stabilizing.
I think Van got it about right - a slight amount of forward tip so the weight effect augments the castor effect.
It has been a long time since I studied castor shimmy, so this might not be correct, but I think shimmy occurs when the natural frequency of the yaw oscillation 'spring' from castor coincides with the natural frequency of the yaw oacillation 'spring' from vertical displacement. They feed each other like a flutter mode.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
Hobbs 635
Old 03-23-2020, 06:26 PM
Ed Holyoke
Ed, what you describe sounds like the lower end of the pivot axis is forward of the upper end of the axis. So can you clarify what you mean by 'shaft pointed forward'? It seems to me that if the upper end of the shaft is forward, then the weight effect will help keep the wheel straight.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
Hobbs 635
