Garmin G5 stability
tomww
Active Member
I have been told that if the G5 has a GPS outage the ADHARS will slowly topple. I am told that the system is dependant on using the GPS as a reference.
Is there anyone who knows if this is true ot not?
G5 GPS Information
Good Morning,
The G5 can use air data information to correct for sensor drift in the absence of GPS data, but the highest level of performance and accuracy is only obtained when GPS data is available and used for aiding. That being said, the G5 was proven to meet minimum performance requirements both with and without the use of GPS information in the attitude calculation.
Justin
Does the "air data" include 3-axis magnetometer? If so, is there one in the unit, or does that require the remote magnetometer?
Good Morning,
Justin
Thanks for the quick reply Justin. That is what I wanted to know.
