Old 05-10-2022, 11:10 PM
idubrov idubrov is online now
Default RV-7 #75069
Started building an empennage kit of RV-7. Made some progress working on the vertical stabilizer.
And this is my damaged front spar assembly for the vertical stabilizer:
https://ivan.aero/images/VS-705-dama...op&w=600&h=800
Lesson? Don't try to fix what is not broken
Ivan Dubrov #75069
Building an RV-7
San Antonio, TX (near 1TT8 Bulverde Airpark)
My build log
Old 05-21-2022, 10:48 AM
After many working sessions, getting to the point of no return: this nose rib is going to be hidden inside the part!
Looks good to me. Couple of rivets are not exactly straight, but this should do. I noted that I instinctively tend to get shop heads on a smaller side. There was one head ~0.126" (which is still good according to the spec, which gives ~0.122" minimum for 3/32" rivets), but I hit it few more times.
All updates
Ivan Dubrov #75069
Building an RV-7
My build log
Old 05-21-2022, 05:22 PM
Mr_Sierra_Juliet Mr_Sierra_Juliet is offline
Ha! Small world, I'm RV7 75070! I'm a long way behind you thanks to Vans loosing my final payment for a month and living in the UK so no doubt further shipping delays there!
I'll follow you with interest if for no other reason than your builder number and for knowing what's next in my build!
S
Old 05-21-2022, 11:19 PM
Welcome-welcome!
Meanwhile, horizontal stabilizer is complete! Turned out, I was intimidated by the rivet gun for no reason. Running 3/32" rivets with the mushroom set is nothing to be scared of (I am still intimidated by the universal head -4 rivets, but I'm sure, I'll get there).
I was thinking to show my rivets to somebody before I close the part, but I couldn't hold myself from finishing it. Not much to see there anyways, all the rivets are perfect
All updates
Ivan Dubrov #75069
Building an RV-7
My build log
Old 05-24-2022, 10:15 PM
...and vertical stabilizer is finally complete, too (after rebuilding the whole front spar assembly).
Some random rivets inside the vertical stabilizer (I think, they look worse than the horizontal stabilizer ones, but hey, it took me much less time!)
Does not look like my dimples are crisp enough! However, I think, truly crisp dimples are a myth
Ivan Dubrov #75069
Building an RV-7
My build log
Old 08-03-2022, 03:12 PM
Okay, so the empennage parts are somewhat complete (except for the fiberglass and fitting parts together).
Still debating if I want all fairings to be removable or just the rudder bottom one (and maybe the elevator ones, so I can keep additional counterbalance weights inside them).
Ivan Dubrov #75069
Building an RV-7
My build log
Old 08-03-2022, 04:58 PM
Taltruda Taltruda is offline
You can get crisper dimples.. they aren’t a myth. Cleaveland tool has a great YouTube video you can check out showing the difference between under dimpled and right ones. You either need to squeeze or hit harder, but also check the brand dies and if they aren’t quality ones such as brown, Avery or Cleaveland, you might find a difference there too.
https://youtu.be/DxQwh-X8gOc
https://youtu.be/Qo9QCMaNSoA
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 08-03-2022, 05:40 PM
I know, I was being a bit sarcastic, given all the discussions about "crisp dimples" I've seen. I primarily use DRDT-2 which I think I set up properly (lots of pressure).
I'll try more pressure (or maybe buy Cleveland dimple dies).
Ivan Dubrov #75069
Building an RV-7
My build log
Old 08-17-2022, 04:20 AM
swift12 swift12 is offline
Buy Cleaveland dies….I have others but only use them on non visual stuff and grinding the edges on them. I have three sets of 3/32 Cleaveland dies. One has been ground. My fav set and a backup set in case. I have 1/8” dies and all the screw dies from them. They make the best dimples from my testing.
2022 dues paid gratefully. great site for help and info.
Old 08-17-2022, 07:31 AM
wirejock's Avatar
wirejock wirejock is offline
Default Finishing
The pull rivets can be removed if you really want to remove a tip. That also means they can't be covered or the seam bonded or sealed.
The other method is to add a nutplate to the forward tooling hole on the elevators.
The rudder has a counterbalance but the part is not balanced before finishing.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
