Old 02-11-2021, 06:29 PM
glenn72pc glenn72pc is offline
Default Io 540 plenum
Looking for a Plenum for my RV 10 io540 not a Sam James plenum possibly one that was built for the stock cowling or if somebody has a mold and is willing to rent or produce a plenum for me also I remember seeing somebody from South Africa producing these plenums but I have been unable to find that source
Old 02-12-2021, 12:15 AM
rongawer rongawer is offline
Youre likely looking for http://rvbits.mybigcommerce.com/cate.../Engine-Parts/
However Jan stopped advertising his carbon fiber plenum due to the high cost of shipping. If you email him at his contact on the site, Im pretty sure hell still make a plenum for you if youre up to the shipping cost.
Ron Gawer
- RV10, N762G, Build in progress.
- Several others that are now just great memories for me.
Old 02-12-2021, 09:28 AM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Why not just make the plenum. Its not hard at all and would be a great learning tool in fiberglass.. You can find lots on help and guidance online too..
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 98%, Working on Fuselage, AEIO-540 on the stand
Acro Sport 2, building
Old 02-12-2021, 06:07 PM
rvdave rvdave is offline
Smile
Id be curious to know what the advantage is if any to a plenum vs standard cowling rubber? Could there be a less drag/ speed advantage? I have standard with no cooling issues but would always be interested in less drag/ more speed
Dave Ford
Cadillac, Mi
Old 02-12-2021, 06:35 PM
Default Plenum
I have no issues with cooling speed extra speed would be nice but my main goal is to take the load off of the cowling my Engine cowling halfs used piano hinges to keep them together and I can see how theyre being affected by the pressure within the cowling
Old 02-12-2021, 08:15 PM
Toobuilder's Avatar
How are the cowling hinges being affected by the pressure within the cowling? There are 10's of thousands of airplanes with piano hinges holding the cowl together.
Heck, I have a plennum and the whole top lid is held on with piano hinges.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 02-12-2021, 11:42 PM
ReidVaitor ReidVaitor is offline
Personally, the plenum allowed me to control the air over the cylinders. My #6 was always hotter than the rest, by putting deflectors and other attached to the plenum I was able to move it off of #4, cooler than most, and get the temps down on 6 now its all within 10f. Not something I could do with baffling and the top cowling. There are, of course numerous ways to resolve the same issue using baffles but not nearly as controlled as a plenum.
As for the easy way to do it yourself? Use the top cowling as a mold, put about 3-4 ply over it and you have the start of a plenum now you need to create a nice way to attach it. Instead of rubber use a thin L bracket - match drill and you have a nice plenum without shipping costs.
Best of success!
Old 02-13-2021, 05:37 AM
Capflyer's Avatar
Capflyer Capflyer is offline
Read this study http://www.sonex604.com/misc/NASA_CR3405.pdf
Mike
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 02-13-2021, 10:45 AM
Toobuilder's Avatar
A plenum does not need to be complicated.
I used the "stock" baffle sides as a basis for my plenum and simply added a flat wrap "lid" made of .016 2024. As mentioned, held in place by piano hinge on all sides. Takes 30 seconds to remove and 2 minutes to install (no tools).
Click image for larger version
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 02-13-2021, 11:10 AM
DanH's Avatar
DanH DanH is offline
Mike, are those Rutan Boomerang style inlet?
As others have noted, a plenum is just a lid. Details like attachment are important, but there a lots of ways to do it. The most critical factor is probably the inlet and ducting into the plenum, in particular as the inlet velocity ratio moves closer to freestream velocity.
Dan Horton
RV-8 SS
Barrett IO-390
