Keep VAF
Going
02-21-2021, 08:55 AM
Beep....beep...
Thread drift...a trim "beep" tone when the trim motor runs has been pretty much standard on (almost) all the large aircraft I’ve flown. Where would an experimental aircraft equivalent fall on the technical/practical/Human factors/“worth the effort” scale?
Initial thoughts (in answering my own question  I doubt the "beeps" would help much in a runaway situation where the trim was commanded to run at full speed while on autopilot...but if you're at cruise and you hear more than a very few and very occasional beeps, you’d likely know something is wrong before it got ugly. If the VP-X (or similar device)is set up to run trim speeds at substantially slower rates when above 100 knots, a lot more beeps would have to be ignored before things got ugly. ?
(Thanks to the OP for starting the thread)
Sam
SEMO
Emp. complete
Waiting on RV-8 QB Fuse/Wing
currently (over) analyzing the options.
2021 donation…check
02-21-2021, 10:57 AM
Thoughts on Runaway Trim
Much of my flight time before starting my -8A build was in the Navy A-4 Skyhawk, where runaway elevator trim was an immediate action emergency. Gave a lot of thought to that in my panel design.
Forward three switches on my switch panel: Elev Trim Power; Aileron Trim Power; Autopilot Power. Have never had reason in 1300+ hours to activate the first two in flight, but have used the A/P power cutoff. If building now, would eliminate the first two. Didn't think the power cutoff switches could be activated in time to stop full runaway, but could prevent further random trim inputs caused by uncontrolled electrons.
Didn't have the Flight Test docs in Phase 1 in 2012 but one of the early tests I conducted was full nose up trim and full nose down trim over slow to fast cruise and landing speeds. For nose down scenarios I let the nose drop to various attitudes before initiating recovery. For slow nose up scenarios, immediate unload to zero g, stop any roll, get the nose down then sort things out.
The -8A was controllable - admittedly sometimes uncomfortably so - at all test points.
The key - just as was shown in the 737 Max debacle - was to control the nose-low airspeed by reducing power to idle as soon as possible. With a constant speed prop, airspeed reduction is pretty quick. I never got near Vne.
This was for an -8A with fairly forward CG. Your results may vary.
02-21-2021, 11:18 AM
Don't forget that if you are like the OP, and you have a Garmin G3X or G5-based autopilot with GSA 28 autopilot servos that drive the aircraft's DC trim motors, then simply pressing the AP DISC button on the control stick will interrupt power to both the autopilot servos and the trim motors.
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
02-21-2021, 04:12 PM
Sam,
The VP-X and other modules that run trim don't normally directly connect to the audio system. In the case of the VP-X, it sends a signal to the EFIS whenever the trim is moving, and then it is up to the EFIS (which is normally connected to the audio system) to generate a tone if that vendor so chooses.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
Fly Navy!
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
02-22-2021, 09:13 AM
Runaway Trim vs Disconnected Manual Trim
Manual trim malfunctions can be really scary too (and yes, they do occur)!
During my first two years of ownership my RV7A had manual trim. Twice during that period the trim cable became disconnected from the trim knob where the two join. Both times this occurred immediately after takeoff when I was adjusting for climb out speed.
The aircraft immediately acted as if it has full nose up trim and became a handful to fly and created a real interesting landing problem. Of course the faster one flies the greater the out of trim pressures. There’s nothing like landing an airplane where you release forward pressure on the stick to touchdown. Not a pretty landing!!!
Those two experiences convinced me that “runaway trim” couldn’t be any worse than a manual trim cable disconnect. At least with runaway trim I should probably have some indications that trim is moving in a direction that I don’t want. With a manual trim cable disconnect it happens suddenly!
Those two incidents convinced me to convert to electric trim and I haven’t regretted the decision. I did use the Pat Hatch UTRB module with Tosten military style grips. I’m also getting ready to install the TruTrac Autotrim Module that a friend (who has manual trim) didn’t use when he installed his autopilot.
Let’s face it. There isn’t a system designed by men that isn’t subject to unexpected failures. Just be prepared to handle them when (not if) they occur. As the saying goes: sh** happens!
Jim Harris, ATP, T38, EC/KC-135A/E/R, 2008 RV7A, 2nd owner, N523RM (2015)
Superior XPIO-360, Hartzel CS prop, Aerotronics panel with Dual GRT Horizon WS, EIS, Garmin 340, 335 w/WAAS gps, Dual 430s (non-WAAS), TruTrak 385 A/P with auto-level, Electric trim, Tosten 6 button Military Grips, FlightBox wired to WS, Dynon D10A w/battery backup, 406 MHz ELT. Custom Interior, New TS Flightline hoses, Great POH!
Retired - Living the dream - going broke!
02-22-2021, 10:04 AM
That is not correct.
In my case the AP had nothing to do with the trim issue. They are two different motors, and while the G3X will drive the trim.
Disconnecting the AP would have done nothing. In fact the GARMIN setup immediately disconnects the AP if it detects a trim input from one of the switches. That was in fact my first indication that I had a problem.
-Dan
Dan Weyant
RV-9A N96KD
Done and Flying 4/30/2015
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
