Keep VAF
Going
12-16-2020, 12:40 PM
Originally Posted by andrewtac
Every prestart check when I check circuit breakers in I put my fingers on the trim circuit breaker. I might add an switch on my 10 to be able to interrupt up after seeing this. Need to do some research. Thanks for sharing, got me thinking.
I put my trim and autopilot pullable CBs right in front of the pilot, marked with a line around them. (Since the Trio can do auto-trim, in a runaway I need to pull both breakers immediately, then sort out the problem.)
Right seat has its trim switch on the panel. Too many stories about passengers resting a book on their stick trim switch.
12-16-2020, 12:45 PM
I have the Dynon autopilot panel which also controls the elevator trim. Even when flying manual the trim switch actuates whatever is in the box and so drives the trim motor. There is a safety feature which allows only 3 sec of trim at a time. But I donīt see how this thing is build and thought trim runaway could be possible.
So I installed a guarded switch which selects power to the trim motor from the autopilot/trim panel or - when the guard is open and the switch activated - to a second springloaded alternate trim switch (no electronics inbetween). I believe this reduces the chance of trim runaway considerably.
I also have a collar on the Trim C/B to be able to quickly locate and pull it
RV-7 flying, IO-375 w. P-Mags, 200RV Prop
RV-8 flying, IO-375, P-Mags, 74RV Prop
12-16-2020, 07:43 PM
I am glad to see this issue getting some attention. I am also glad to hear that the OP was able to control his AC in a very extremis situation. I can add nothing to the suggestions already made here regarding fixing his problem. I can add my opinion about the system and what I did to mitigate runaway trim risk
My opinion is that the typical RV trim system in general has more trim authority than necessary. There is no option that I know of to limit the travel of the typical Ray Allen trim servo. During Phase 1 while simulating run away trim, it became very obvious that stick forces could potentially build to disastrous levels pretty quickly in some flight regimes.
My approach was to add a TCW system set to a very short trim cycle (about three seconds) and run the trim at very slow speeds.
For those who are relying on reaching a circuit breaker to stop a runaway, I suggest that you run your trim donward at max cruise speed for about three seconds and then see if you would like to remove one of your two hands that will be fighting the forward stick pressure to pull that breaker. Not saying it is undoable, just probably harder than you imagine.
In addition. I "biased" the trim servo so that it can run the servo in nose down trim only the amount necessary to trim for level flight at max cruise speed. this leaves a lot of trim authority in the nose up direction, but my thinking is that a nose up runaway is much easier to handle than a nose down one. As the nose goes up, with a timely power reduction, airspeed will bleed off quickly to a point where reduced trim tab authority could be overcome by stick pressure and balanced flight (or at least manageable forward stick pressure) could be achieved without disaster.
Looking back at it, I would probably install manual trim. With the inclusion of auto pilots that drive the trim tab, there is a bunch of trust and complexity built into a system that should be kept very simple.
All IMHO of course.
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
12-17-2020, 06:34 AM
I'm pretty sure most RV guys would find this overkill/to costly but this is the 'old' way to avoid trim issues. You have to push both switch sections to activate trim, one switch is for trim and the other is for trim power. So power is shut off to the system unless you operate both the power and trim switch simultaneously. I've considered installing this myself as I don't use aileron trim anyway.
Switch quality is another factor, check out the Otto switches and compare them to what some other grip manufacturers choose to use, you get get what you pay for. Check out the Otto grips vs another popular 'military' grip maker, the price difference is mostly the quality of switches used.
In reality I think good wiring practices along with good hat switches and the Garmin limit function is a pretty safe bet, and no way I'm giving up 'autotrim'.
Slowing down is the first thing to do with out of trim situations, much less force required at slower speeds.
Links to switches and grips:
https://www.aircraftspruce.com/catal...istolgrips.php
https://www.aircraftspruce.com/catal...mSwitches2.php
https://www.aircraftspruce.com/catal...ch11-15410.php
https://www.aircraftspruce.com/catal...ickkey=7529516
https://www.aircraftspruce.com/catal...clickkey=13068
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
12-17-2020, 07:44 AM
Dan,
I have the same setup in my 8 and as others have suggested, I would suspect a problem with either the switch or a short somewhere in the wiring. Since you were able to control the trim with the soft keys I would suspect the former. Just curious, but did the VPX present a fault message when the trim ran away? In addition to the advice from the G3X experts, it might be worthwhile to run the VPX configuration routine outlined in the installation manual to verify you have it programmed the way you want it.
Good job getting on the ground safely, especially with this problem on an approach down to minimums.
J. Baker
12-17-2020, 07:55 AM
I've seen posts in this thread and others about having circuit breakers on the trim servos so that you can pull them in the event such as this. I'm actually at the point in my panel layout were I'm locating some of the breakers and in fact on this iteration I have breakers for the pitch and roll trim to the GAD27 power inputs. My question is how does this solve the problem if the servo has run to an extreme limit?
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
12-17-2020, 08:06 AM
I realize a trim runaway is disconcerting, but it may not be something worth adding a lot of backup/safeties/support systems, which often bring new issues into play. The aircraft is controllable with trim at the limits. Stuff not installed has a perfect reliability record.
Dan Horton
RV-8 SS
Barrett IO-390
Lesson from the 737Max
I just started building my fuselage when the 737Max double crashes happened. I didn't know these big birds have the build in trim cutout switches to prevent the runaway trim. Unfortunately, the pilots of the doom planes didn't use them.
From that lesson, I now have the trim cutoff switch and the flap cutoff switch mounted directly in the front panel. These two switches will be normally on all the time to provide power, except for the case I think the trim motor is misbehaving. Then it is a simple step to flip the switch to off and cut off power the motor. This action is much faster than pulling circuit breaker or fuse. They can be pulled at anytime afterward.
I have the flap cutoff switch for the same reason. I purchased the Flap Positioning System from Vans, which included a flap controller. I discovered during the installation that if the guide-rod isn't properly aligned, the flap motor won't shut itself off. So that is the reason to have another cutoff switch.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Done. Fiberglass 80%
Avionics Installation -- 90%
Firewall Forward -- Engine hung
Electrical -- 90%
Donation paid through 2021
12-17-2020, 08:29 AM
Originally Posted by Walt
Though not as handy as this high dollar switch, I put a simple trim power toggle switch on the panel. I switch it on and trim with the stick grip hat switch, then turn off the power. Runaway trim scares the heck out of me.
David C.
Howell, MI
12-17-2020, 09:15 AM
Trim runaway cutoff switches? By the time a pilot realizes what is happening and flips the switch, the trim will already be nearing the limits. Even less time if the autopilot was engaged.
As Walt said, the runaway trim response is to simply slow down. Next flight, back it off to 100 knots and run the trim to the limits, because chances are that's where it will be, even with a cutoff switch. KIS.
Dan Horton
RV-8 SS
Barrett IO-390
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
