Old 02-19-2021, 08:40 PM
RV12Pilot RV12Pilot is offline
Default RV-12 ICAO Code
I have the classic Dynon Skyview in my RV-12. Which ICAO Code(s) should I use to identify myself for flight following purposes? Thank you.
Old 02-19-2021, 09:49 PM
For flight following just identify yourself as an RV-12 to the controller. If you are an ELSA you are required by your operating limits to also state you are an experimental RV-12.
Old 02-20-2021, 05:37 AM
Default RV-12 ICAO
Thank you sir
Old 02-20-2021, 08:27 AM
h&jeuropa h&jeuropa is offline
If you are trying to figure out the code for filing an ICAO flight plan, this link will help:
https://ipadpilotnews.com/2020/08/ho...-flight-plans/
Jim Butcher
Old 02-20-2021, 09:33 AM
DHeal DHeal is offline
FAA/ICAO code for the RV-12 is: RV12
https://www.faa.gov/documentLibrary/...tors_FINAL.pdf
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,000+ hours (as of Feb 2021)!
VAF donation through June 2021.
Old 02-20-2021, 10:53 AM
jrtens's Avatar
jrtens jrtens is offline
If you are looking for the codes to put in the ICAO flight plan,
1800wxbrief.com
planning section will help you find the correct codes.
Jon
12iS SLSA #5
Salt Lake Int'l
Old 02-28-2021, 03:11 PM
Default ICAO code for RV-12
Thanks all
