Old 02-06-2021, 08:10 AM
Kojo Kojo is offline
Default QB Garmin pitot installation - Help!
Does anyone have some perks on the installation of a Garmin pitot. I purchased the mount but when I received my WB wing, thsspar appears to have nut plates in the location of the spar to receive the access plate W-822PP. Curious to know how anyone had got around this.
Old 02-09-2021, 07:19 AM
YvesCH YvesCH is offline
Hi,
I made a doubler and used a angle piece to attach the doubler to the wingrib. In forward direction i used the same rivets as for the skins (just longer ones).
ID:	8131  Click image for larger version
ID:	8132  Click image for larger version
Yves - Basel, Switzerland
RV-8 #83458 HB-YUA
Donation 2020 done
Old 02-09-2021, 09:57 AM
goatflieg's Avatar
goatflieg goatflieg is offline
This is how I did it. The location is just on the outside of the rib by the access cover for the bellcrank. Instead of using a skin doubler I made an aft end brace to help support the mast more securely.
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - empennage at hangar; currently working on finishing canopy & wing tips.
N657AR reserved
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2021... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 02-11-2021, 06:35 AM
Your response has been a tremendous help, thanks!! Kojo
