pilot28906
My left stick has too much back and forth slop/play. I installed this some time ago but it seems that I may have opened up the ID of the steel tube on the assembly too much due to using 3/8" drill instead of a reamer. How is the best way to fix this? I looked for an over sized brass bushing on the OD but cant find the correct OD size with a 1/4" ID. Not sure why, but the right stick is perfect. All suggestions welcome.
Thanks.
Thanks.
