  #11
Old 03-10-2020, 08:14 PM
PilotjohnS PilotjohnS is offline
Default Divide by two
Originally Posted by RV8Squaz View Post
Hey Ralph,
FYI, 1" displacement, 36" from the axle gives me 1.59 deg. Someone please check my math.
It should be 1/2? per wheel for the calculation since you want each wheel to the centerline , not to each other.
John S
Dues paid 2021, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 35% in work
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
Old 03-10-2020, 08:17 PM
tomkk's Avatar
tomkk tomkk is offline
Originally Posted by pilotyoung View Post
Jim,
Some people say those tires are much heavier than the original tires. Has that created any problems for you?
Thanks.
John
Yup, mine were heavier. But, I got 265 landings on the original tires, over 900 on the Desser Retread Elites. Undoubtedly at least some of that is more experience with the aircraft but IMHO it was mostly the tires.
Tom
Port Orange, Fl
EAA #51411
swjohnsey swjohnsey is offline
Instead of trying to calculate the toe-in you need you can measure it with this clever little tool.
https://www.ebay.com/itm/Gunson-G400...kAAOSwa9FbBpFV
Old 03-10-2020, 08:32 PM
tomkk's Avatar
Interesting. I wonder how it works - it looks like it might depend on the side friction of a tire that isn't rolling exactly straight over the gauge. If that's the case, I wonder how well it would work on or aircraft tires - our tires have such a smaller footprint than auto tires, especially our high camber tires.
Tom
Port Orange, Fl
EAA #51411
Old 03-10-2020, 08:42 PM
It measures scrub. There are two platforms separated by rollers so very little friction. There is a pointer attached to the top platform that indicated too much toe in or toe out. I've never tried it on the airplanes but it works well on my Lotus 7 with around 400 lbs/wheel.
Old 03-10-2020, 10:39 PM
DHeal DHeal is offline
If you are looking for a really long straight reference beam to measure toe-in/toe-out consider using two 4'-6' fluorescent light bulbs each placed against the side of each wheel hub or brake rotor. Be careful though -- the bulbs tend to shatter if mishandled.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 980+ hours (as of Dec 2020)!
VAF donation through June 2021.
Old 03-10-2020, 10:45 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Jim,
Thanks.
John
No problems. Need to shave wheel fairings for 1/2" tire clearance.
Jim Stricker
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 633
Old 03-11-2020, 02:11 PM
Ralph Inkster Ralph Inkster is offline
That's what I got too. You need about a 5' straight angle, not 3', to get 1" = 1 Deg.
Yep You're all right! Shouldn't trust old guys, or should give them less beer.
The length should be 57.3" to get a 1" sweep to equal 1 degree.
General concept is still simple & easy to do though.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 03-11-2020, 02:23 PM
NO, we are not suggesting a 1 degree toe in or out. Was just suggesting a different way to determine each wheel's angle before shimming.
Yes, you would have to add the two results to set your desired overall toe in / out.
Ralph
Old 03-11-2020, 04:15 PM
rvbuilder2002's Avatar
Remember that the toe value check is relative to the aircraft center line. Not the two wheels to each other.
It is not uncommon for the production tolerance to have one leg with toe in and the other with toe out. If checked in relation to each other, it may look like it is perfect but your airplane will move in a straight line yawed to one side.
Scott McDaniels
Hubbard, Oregon
