  #211
Old 09-12-2014, 11:15 PM
JAE JAE is offline
Default Engine Mount Bolts
I made a locking device to prevent the bolts coming out.
1/Purchase qty 4, 5mm bolts approx. 20mm long, Bolt heads should be same size as the hex in the socket headed engine mount bolts.
2/ Fabricate from alloy bar, 4 pieces to the internal diameter of the steel engine mount tube that the engine mount bolts are recessed into and approx. 1/8 in longer than the distance from the head of the bolt to the outside edge of the steel engine mount tube. Thread the centre of the alloy bar plugs with a 5mm tap. Screw the 5mm bolts into the plugs using Locktite.
Ensure the engine mount bolts are Locktited and torqued into the engine.
Install the alloy plug into the engine mount tube ensuring that the 5mm bolt head is engaged into the hex of the engine mount cap bolt.
Using a 1/16in drill, drill a hole through the steel enine mount tube and the alloy plug approx. 1/8in from the outer end of the steel engine mount tube. Install a 1/16 S.S cotter pin through the hole and fold over the tails.
This should prevent the problems of the engine mount bolts coming out.
Old 09-13-2014, 07:11 AM
Dave12 Dave12 is offline
Pictures man, pictures!
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Old 09-15-2014, 04:34 PM
Buzz J Buzz J is offline
Default Applause and gratitude for a job well done & request for pics
Jim,
What a terrific, creative solution to ensure a redundancy factor to this concern for all 12 builders/owners! You put your aircraft engineer experience to work! I'm impressed and very grateful! Possible to get some pics either via this thread or by email? Thank you so very much!
Buzz Jensen
Old 01-05-2016, 11:42 PM
Slane Slane is offline
Default Mounting bolts still holding...
I did the 100 hour ROTAX maintenance check and am happy to report that each of 4 bolts had maintained the 30# torque.
Old 02-24-2016, 04:53 PM
Chopkins Chopkins is offline
That's a very clever solution. Nice one!
Anthony
Old 12-23-2017, 09:14 PM
LUKLA's Avatar
LUKLA LUKLA is offline
Default Rotax torque/chart
Folks,
Where can I find Torque Chart/Table for 912 ULS?
I could not find any where. If you guys could give me the specific manual and page #. It would save my **** load of time.
Lukla
Lukla
Glendale AZ
RV-12
N316AM
Flying since June 2018
150 Hrs and Counting
Old 12-30-2017, 12:18 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
I searched this thread... trying to find metric allen wrench size to fit the engine mounting cap screws so I can have correct tool at hand when I next remove cowling.
Does anyone know metric allen wrench size?
I'm thinking 3/8" socket extension will allow me to torque bolts once I cut access hole in fiberglass cooling shroud. Am I making correct assumption here?
Thanks in advance...
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 750
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 12-30-2017, 01:51 PM
John-G John-G is offline
Jim,
I purchased a set of inexpensive metric 3/8" drive hex sockets from Harbor Freight. The set had the correct size for the engine mounting hardware ... which, if memory serves me correctly, was 6 mm (but don't hold me to that).
https://www.harborfreight.com/6-pc-3...set-69546.html
I also purchased the extended ball tip version when they were on sale for around $9.
Happy flying .... after spring thaw LOL
John
http://www.dogaviation.com/
RV-12 Wings, Empennage, Fuselage, Finishing, Avionics and Powerplant kits all completed
Now Flying!!
Donation paid until September 2021
Old 12-30-2017, 03:47 PM
DaleB's Avatar
DaleB DaleB is offline
I seem to recall they were 8mm... but I wouldn't swear to it in court. I used a 3/8 drive like the Harbor Freight link above, with an extension and torque wrench.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 12-31-2017, 07:30 AM
Jim-
Thinking about it Dale is probably right about 8mm being the size for the hex socket needed and it is in the HF hex set.
John
Now Flying!!
