Old 10-06-2021, 09:10 AM
amekler amekler is offline
Default setting up trim for takeoff 1st attempt issue
I'm not sure my trim is correctly set up. I followed the procedure in the setup for full up full down and takeoff
it said calibration accepted but I see no markings on the trim indicator.
I'm also confused when you engage nose up which way should the tab move?
any help pictures appreciated.
Alan
N603NH RV-12 almost done
Old 10-06-2021, 09:24 AM
swjohnsey swjohnsey is offline
Nose up the trim tab should move down.
Old 10-06-2021, 09:42 AM
Mel's Avatar
Mel Mel is online now
Believe it or not, about 1/2 of all airplanes I inspect have the pitch trim set up backwards.
Easy way to remember is that the tab "flies" the elevator/stabilator, not the airplane. If the tab is down, it forces the elevator/stabilator up. And vice/versa.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-06-2021, 09:46 AM
thanks
I think mine is wired backwards hence no trim indication
will check
Alan
Old 10-06-2021, 10:07 AM
CD. CD. is offline
Mine was wired backwards when I became the owner... the plane had been that way for 11 years. I couldn't stand it... swapped the wires at the servo and life is much better now.
Old 10-06-2021, 10:51 AM
wcalvert's Avatar
wcalvert wcalvert is offline
Flown with the trim reversed for 11 YEARS?!! Wow
RV-7 Tipper
Bill (Wild) VA-165 '90-'93
Anacortes, Wa
First Flight 7/17/2021!!
- Been there, Donated 2022
Old 10-06-2021, 11:17 AM
rvbuilder2002's Avatar
Or in another way to look at it... the tab (regardless of whether it is on a traditional elevator or a stabilator) should always move in the opposite direction of the trimming function.
Trim switch activated for nose up - the tab should move down (and visa versa)
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 10-06-2021, 11:23 AM
Not necessarily unusual depending on the configuration of the pitch trim switch.
In instances where the switch is panel mounted, it could be either way depending on a persons preference / logical reasoning....
Should you push the top of the switch for nose down trim (I.E., rolling the switch fwd. akin to turning a trim wheel fwd., or push the bottom of the switch for going lower?
Just another of the never ending debates
If the switch is on the stick, there should be no debate.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 10-06-2021, 11:40 AM
Pilot8 Pilot8 is offline
Two white wires that run the length of the airplane, which are also polarized; what can go wrong?
Old 10-06-2021, 02:03 PM
gasman gasman is offline
Van's manual trim...... turn it one way, if the plane doesn't do what you want, turn it the other way.......
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
