Old 09-19-2021, 08:36 AM
Bob Y Bob Y is offline
Default 912iS - Hobbs vs. ENGINE Time
I'm pretty sure this is a 912iS only item...
What's the difference between Hobbs vs. "ENGINE" time in the EMS? When I first energized my HDX system, the Hobbs showed zero, naturally, but there is a timer labeled "ENGINE", which showed 0.5 hours. I naturally assumed this was from the factory break-in period. Slowly, Hobbs has overtaken the ENGINE time. With over 100 hours on the engine, the Hobbs has gained about 45 minutes over the ENGING timer - now 112.5 on the Hobbs vs. 112.3 on ENGINE time. See attached screenshot of my EMS screen.
I've checked the Rotax manuals, floated this question to Dynon and on the Rotax Owner's forum, but no good answers, so, I'm reaching out to you iS engine guys with two questions:
1. Does anyone know the real meaning of ENGINE time?
2. How do Hobbs vs. ENGINE times compare on your aircraft?
Name:	Hobbs vs Engine Time.pdf
Bob Y - builder 12iS E-LSA
N569TT first flight 2/9/2020
#121047
Old 09-19-2021, 02:38 PM
Desert Rat Desert Rat is offline
Hobbs just ticks over .1 hours every 6 minutes. Some of them are wired to start ticking when you turn the master on, some are on a switch so they don't start until oil pressure comes up.
Assuming 'engine" time is the same as what the certified world calls "Tach time," it works like on a tractor or other random farm equipment- i.e. it ticks .1 hour every 6 minutes at full power but when you reduce r.p.m. it slows down proportionally.
Traditionally, you log hobbs time in your logbook but schedule maintenance by tach time.
Edit- I'm not talking specifically about your airplane, just industry standard.
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 09-19-2021, 05:18 PM
rvbuilder2002's Avatar
On G3X engine time is the same as the traditional aircraft tach time.
Rotax specifically states that all engine inspection and maintenance is to be done based on Hobbs time.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 09-19-2021, 05:33 PM
Scott, thanks for the clarification re; Rotax. I love learning new stuff.
Terry Shortt
Fuselage in process
#72651
Old 09-19-2021, 08:34 PM
Guys, I get Hobbs vs. tach time and understand maintenance is based upon Hobbs. These are produced from the HDX and run per the conditions indicated on the attached from the HDX user manual. This “ENGINE” time is generated by the Rotax ECU, not the Dynon system. That’s why it showed 0.5 hours when the HDX was first powered up - it was served up to the Rotax EMS from the ECU. So, I’ll repeat my second ask in my initial post: Can I ask those of you with an iS, and maybe an HDX, if it’s Dynon specific, how your Hobbs vs. “ENGINE” times compare. And certainly if someone REALLY knows what “ENGINE” time means, please share. Thanks in advance for your support.
#121047
Old 09-20-2021, 09:18 AM
jcl777 jcl777 is offline
After the flight home when I took delivery of my RV-12iS, my G3X Touch showed 19.9 engine and 19.3 total. Today it shows 122.2 engine and 122.9 total.
John Leon
Kingwood, TX
RV-12iS, N221TF, #121130
Old 09-20-2021, 01:04 PM
fehdxl fehdxl is offline
I think these screen captures from the Rotax Maintenance Manual Line agree with that statement…. But, a related question is does the Rotax FADEC provided “Engine Time” accrue like a mechanical tachometer where the ‘tach time’ isn’t equal to watch time except at a certain RPM -OR- like a hobbs where it records watch time once it’s powered from a sensor (oil pressure, master switch, wow, etc)
Thanks!
-Jim
P.S. Added a picture of our RV-12iS times from a couple weeks ago…. The G3X is set to record Total Hours using the airborne option (i.e. GPS and IAS derived).
ID:	16039  Click image for larger version
ID:	16037  Click image for larger version
ID:	16036  Click image for larger version
Old 09-27-2021, 09:38 AM
jrtens's Avatar
jrtens jrtens is offline
I couldn't find a purpose for that engine time either so I just removed it from the display.
Jon
2019 12iS SLSA
Salt Lake Int'l
Old 09-27-2021, 09:53 AM
I still haven’t found an authoritative answer to this question either, but I’m starting to wonder if it might start timing when the oil hits the magical 120 degree point? Would sort of correlate better with the Hobbs readings.
#121047
Old 10-01-2021, 01:23 PM
AlpineYoda AlpineYoda is offline
To date, all my experience has been in the certified world and the above is exactly right. I flew a rental C172 this morning to stay proficient whose tach time was about 70% of the Hobbs time. All these reports of virtually identical hobbs and engine time mean that engine time is accruing too quickly for most people. If you religiously follow 100 hour maintenance, 500 hour mag, and 2000 hour overhaul rules, I think you will be early in all cases, incurring costs before they are really needed. If you can set the EFIS to use a % of max power calculation for engine time / tach time, you might extend parts' effective life per the schedule by 10-30%.
RV-10 build blog -- https://eaabuilderslog.org/?blproject&proj=7ZSwfzr2g
Started 12/19/2019
Engine hung 1/9/2021
Panel hopefully coming fall 2021
N1814T reserved with FAA
Donated Jan 11 for 2021, EAA and AOPA member
