David Paule
If you're using bare Dyneema without a grippy cover, it won't hold a knot under load.
I tried to pull-test some 1/4" Dyneema that I'd knotted and couldn't get any knot to hold under a steady pull. At around 2,000 to 2,500 pounds, IIRC, the bitter end would slowly slither right on through the knot. Didn't matter what kind of knot: I tried most of them that I could think of and used stopper knots too. No joy. It was sort of fun to watch it.
I was an active sailor at the time and reasonably competent with knots then, too.
The pull-test facility manager was so amused that he didn't charge me for the hour's use of the testing machine.
My understanding is that a buried splice will hold, but unfortunately that's somewhat impractical for tiedowns.
There are a number of ropes with polyester covers and Dyneema cores that are strong and will hold knots. A good source for ropes is www.apsltd.com. Give them a call and ask for advice. I'd think that 1/4" diameter for a covered/core high-tech rope is probably sufficient, especially doubled.
Don't forget to pull the rope snug and get the knot up on the ring.
Dave
Dave
