Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
11-14-2022, 09:14 AM
Hartzell Information Manual for Experimental Aircraft
Hartzell has released a document dedicated to propeller vibration compatibility. Apparently it is new, with a cover notation of "Original September 2022".
It lists all the currently approved hub/blade/engine combinations, with restrictions when applicable. Listings include guidance for Continental/Titan and Superior, as well as a few electronic ignitions.
All in all, a convenient and valuable resource for builders who wish to fly behind approved combinations only, and within restrictions.
https://hartzellprop.com/information...ft-manual-193/
Dan Horton
RV-8 SS
Barrett IO-390
11-14-2022, 09:24 AM
Not Hartzell's job, but
Great info. Sure would be nice to have this in .csv or similar format. The resulting searchability would be great since most settle on a PP before a prop. "Cntl F" has it's limits.
11-14-2022, 10:01 AM
Thanks Dan.
One challenge is that many people run electronic ignitions, and it would be great to understand their impact on the prop beyond what Hartzell has published:
Electronic Ignition Compatibility
The combinations listed in Tables 1 and 2 in the Vibration Compatibility Tables chapter of this manual are considered acceptable only with the ignition systems noted. Hartzell is actively testing to investigate the effect that electronic ignition systems have on propeller vibration. Preliminary data has shown that electronic ignition systems can produce increased vibrational loads for the propeller. The specific effects of adding electronic ignition can vary depending on the exact propeller/engine/ignition system combination.
Electronic ignition systems operating at fixed timing also have the capability to increase propeller stresses. At this time, Hartzell can only endorse use with the exact ignition systems listed, in conjunction with the exact propeller/engine combination listed.
Electronic ignition systems in Tables 1 and 2 in the Vibration Compatibility Tables chapter of this manual have been verified to be compatible when tested using the manufacturer's instructions, setup procedures, and preset timing profiles. Changing the timing profile from the manufacturer's settings or other modifications to the setup can change the propeller vibratory loads and is therefore not covered by the compatibility finding.
Use of engines with unverified electronic ignition systems is done at your own risk.
A lot of us fall in the category of "at your own risk" due to running EI, and it seems like Hartzell could do some testing of a few EIs to see if there is an issue. I fully get that this testing is hard and expensive.
11-14-2022, 10:14 AM
Better Searching Available
Scott,
Try an advanced search. I use FoxitReader and it has a decent search function I've used quite successfully.
Thanks, Dan!
Mike
DUES REMINDER: JAN 2023
RV-10
Tailcone 90%, Wings 25%
Fuse Onsite, Finish Ordered, FWF Onsite, Finish Ordered, Prop Onsite, Engine Ordered
11-14-2022, 10:32 AM
Originally Posted by rv8ch
One challenge is that many people run electronic ignitions, and it would be great to understand their impact on the prop beyond what Hartzell has published.
I suspect we need only be patient. I have no inside info, but I do note they called this document "Volume 1"
Dan Horton
RV-8 SS
Barrett IO-390
11-14-2022, 01:29 PM
Thanks Dan.
Does EI really have anything to do with the application? I would assume that is a "catch-all" for any timing that isn't fixed I.A.W. the engine data plate. If I'm missing something or oversimplifying, someone here will let me knmow.
12-01-2022, 05:14 PM
... since most settle on a PP before a prop.
Part of our hope and goal with Manual 193 is that people will start to consider the propeller as part of the powerplant, because decisions about engine configuration will impact propeller options, safety, and/or operating restrictions.
Thanks Dan.
While I understand the frustration, what has been published in the manual either in the text or the combination tables is what can be confidently stated based on the testing conducted so far. Combinations of specific propellers, engines, and electronic ignition systems that we have determined to be compatible are listed in the tables. We have been testing EI systems, testing is still ongoing, and more information will be published when it can be.
We appreciate patience; we're actively working on this but it will take more time. Subsequent volumes will cover other topics, though part of Volume 2 will discuss some further background on engine/propeller compatibility. Additional information on compatible combinations, including information for electronic ignition systems, will be added to Volume 1 via revision as the information becomes available.
Yes, EI can matter to the application, as noted "Preliminary data has shown that electronic ignition systems can produce increased vibrational loads for the propeller" and "Electronic ignition systems operating at fixed timing also have the capability to increase propeller stresses.". The catch all here is not for things that are not fixed IAW the dataplate, it's for any configuration detail that falls outside the published details for the compatible combination; whether that's a change in ignition, compression ratio, or any of the other details discussed in Manual 193.
Trevor Parker, Engineer, Hartzell Propeller
Opinions, information, and comments are my own except as noted. Guidance provided here may or may not be applicable to your specific installation.
12-02-2022, 02:10 AM
Hi Trevor, thanks very much for your responses. I think those of us that have been in aviation for more than about 5 minutes understand that this topic is a real minefield, and that any statements you make can be used in ways that they were not intended. Best of luck with the testing, and please keep us posted on any progress.
12-02-2022, 09:44 AM
I am not able to see anything in the table and I do have Adobe. Am I missing anything or they changed the file to include nothing?
Edit: please disregard as I was not clicking the "volume 1"
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - Out of Paint shop & flying
Dues paid
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
