w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 03-14-2023, 08:54 PM
McSpeed McSpeed is offline
Default PS Engineering Audio Panel PMA7000B
Selling a PS Engineering PMA7000B Audio Panel (panel only).
In perfect working condition when it was removed.
$750 shipped
Click image for larger version
Old 03-17-2023, 09:47 AM
ERJDriver ERJDriver is offline
No Bluetooth correct
Old 03-17-2023, 10:15 AM
Default PMA7000B
No embedded bluetooth. You do have the option to wire an audio connection directly the audio panel to avoid the interoperability problems inherit with Bluetooth.
Old 03-17-2023, 11:03 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
Back in the day you could but not anymore with iPhones that don't have audio connectors.
Sadly sold my RV-8 however still trying to enjoy life by living on my airport with FREE campsites & facilities for ALL visiting pilots to enjoy www.facebook.com/VacaMooAirport/ while my next airplane recently purchased finally arrives !!!!
Exempt by 3 out of the 10 ways but I still donated.
Old 03-18-2023, 04:50 AM
AV8ER's Avatar
AV8ER AV8ER is offline
Default Lightning to 3.5 mm Headphone Jack
It’s still possible with a “Lightning to 3.5 mm Headphone Jack” for about $9. I have the same audio panel as listed here and use a new iPhone for music as OP discussed.
- Tim Jennings
Bought the -10 (Thanks Carl!)
Built the Hangar
Currently building the -8
www.N7ZK.com
"How's it feel to be the fastest plane in the sky? You were spanking two Cirrus planes, a Mooney, and another plane. I took screen shots" - Quote from the best wife in the world.
Old 03-18-2023, 08:59 AM
Pilot135pd's Avatar
That's just for listening so without Bluetooth then you only get half the use.
Old 03-18-2023, 09:59 AM
Default PMA7000B
I will try to bring this back to the original post. The audio panel works awesome. Very easy to use, simple to flip between radios.
As far as the comment “you only get half the use”, as it relates to BT, the PMA7000B does not have BT, period. If you use a Bose headset with BT then your experience is essentially the same as you can listen to music and take a call if needed.
The wired audio input has been addressed below, which solves for music and calls if needed.
The price is now $699 shipped.
Holler if you’d like it.
Cheers all.
Chris
