w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 03-13-2023, 08:27 PM
Thanks for the photos!
Dave
RV-3B now FWF
Old 03-14-2023, 02:34 AM
hoyden hoyden is offline
How hard is it to attach heat muffs? Ideally for MN winter I would like to have two muffs.
RV-6 IO-360, CS
RV-9 QB under construction
Old 03-14-2023, 06:44 AM
BillL's Avatar
BillL BillL is offline
I only used the single AWI supplied, but would recommend two muffs from the start for better heat. Maybe you could get them to add the transfer studs to a second pipe. I have the IO360M1B 180hp, and since a second muff is not fitted can not make a location recommendation.
Bill
RV-7
Old 03-14-2023, 08:32 AM
dpansier's Avatar
dpansier dpansier is offline
I have two muffs which attached very easily, they are configured in series with one position having the welded studs. With two muffs you will have plenty of heat as long as you minimize the airflow thru the known spots.
Don Pansier
Green Bay, WI (GRB)
RV-7
Antennas for Experimental Aircraft
www.deltapopaviation.com
Old 03-14-2023, 09:23 AM
Dad's RV-10 Dad's RV-10 is offline
I just bought an RV-7 with a Sky Dynamics 4-into-1 exhaust and their cold air intake.
I realize the OP is inquiring about RV-9 installations and I don't have much to offer with regard to the installation but the Sky Dynamics 4-1 definitely sounds very nice!
Old 03-14-2023, 04:48 PM
I sent an inquiry to Sky Dynamics for my RV-9. Thanks for the pointer.
RV-6 IO-360, CS
Old 03-17-2023, 07:39 AM
Southern Pete Southern Pete is offline
2 years delivery time on most Sky Dynamics parts.
Old 03-17-2023, 02:15 PM
cjhammes's Avatar
cjhammes cjhammes is online now
Originally Posted by dpansier View Post
Here’s a few photos of the cable hangers on the AWI exhaust system.
Would you mind sharing how you secured the cable loops?
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
Old 03-17-2023, 03:23 PM
BillL's Avatar
Done looks like they gave a crushed tube on the end, like a swage. The stock AWI I received simply recommended to use a center punch and stake the holder from the outside.
Click image for larger version
Bill
RV-7
Old 03-17-2023, 05:10 PM
dpansier's Avatar
I had to shorten the loops a bit for proper clearance, after adjustment, crimped on a short piece of Alum tube on the end of the cable.
Used a standard terminal crimper to make the crimp.
Correction, I used Stainless tube.
Don Pansier
Green Bay, WI (GRB)
RV-7
