w/a Donation
VAF on Twitter:
@VansAirForceNet
  #21
Old 03-15-2023, 06:21 PM
ronrapp's Avatar
ronrapp ronrapp is offline
Is it bad for the engine? Depends on the surrounding circumstances, such as: is it hangared, or parked outside? Is it in a humid environment or a dry one? How often does it sit for 3 weeks straight? If it's an occasional thing, it's probably not the end of the world. The average privately owned light GA airplane flies something like 40-50 hours a year, so many of them do sit. But if it's sitting 3-4 weeks on a regular basis, I'd expect the possibility of some issues over the long term.
As others have said, if it's not going to fly, don't move the prop or ground run it, because you won't get it hot enough long enough to get rid of the moisture inside the engine.
Old 03-15-2023, 08:11 PM
tracy tracy is offline
I would think a fresh oil change and filter would drain a lot of moisture out of engine, then periodically ground run it for 20 seconds as not to get it hot, but lubricate the internals ,would be helpful keeping everything lubricated without any extra moisture forming. This is assuming it’s grounded for maintenance or prolonged weather, and your there to run it.
Tracy Willingham
RV-8
Powered Paraglider
Pitts S2B- sold
Chattanooga, Tn
Dues Paid
Old 03-16-2023, 07:33 AM
pa38112 pa38112 is offline
The amount of water produced by ground running is astronomical - In the gallons range. However only a small portion of that makes it to the oil.
Water in the oil does not really hurt a sitting engine. The problem comes from the protective oil dripping off of the cam and cylinder walls exposing the bare metal to Humidity in the air. It takes several days for the bare metal to become exposed. You can extend that to weeks by using Aeroshell 20W/50 oil and by adding Camguard. This buys you a bit of a safety margin for letting the plane sit a little. – You never know when work/weather/maintenance issues/life will force your plane to sit for a while.
It is important to understand that the moisture we need to fear is the humidity in the air, not the water in the oil. That water tends to be entrapped in the oil.
The humidity inside the engine would be the same whether you have fresh oil, or 100% water in your sump. I know this is not actually true, but it is true from a practical standpoint. In my opinion the most important things you can do are:
1. Use Camguard
2. Remove the dipstick after running. (While an engine is cooling the
moisture in the sump is released into the air and will then condense in
the upper regions of the engine, like the cam)
3. Use an engine dehumidifier – requires significant work for a regular
flyer, so I don’t find them practical. If you know in advance that the
plane will sit, then they are wonderful.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
2008 Wag-Aero Cub C-85
Old 03-16-2023, 08:37 AM
MacCool's Avatar
MacCool MacCool is offline
It literally takes me 30 seconds or less to connect my dehydrator to my airplane...as much time as it takes to open the oil door and stick a rubber stopper into the dipstick tube.
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
Dual Pmags
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
Old 03-16-2023, 08:51 AM
rocketbob's Avatar
Just did an annual inspection on a pristine Piper Archer that's hangared in a well-insulated heated floor hanger that is temperature controlled year round. 22 hours on the airplane last year. Cylinders were full of rust. Its the acids and moisture in the oil that do harm. Not the environment.
Please don't PM me! Email only! rocketbob@gmail.com
Bob Japundza CFII A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Old 03-16-2023, 09:29 AM
JonJay's Avatar
JonJay JonJay is offline
I read an article recently whereby they tested several dehumidifiers. They found all of them worked to lower humidity levels in the case. However, cylinder humidity remained unchanged. If you believe that article, dehumidifiers would do nothing to prevent cylinder corrosion.
I run Aeroshell 15/50 Semisynthetic in my airplanes. I believe a quantity oil with appropriate additives helps a great deal. Both of my airplanes have sat at one time or another for a few months for various reasons and I have never had any corrosion issues, at least in my cylinders.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-16-2023, 10:03 AM
thinkn9a thinkn9a is offline
Default See Lycoming service letter L180B
It says you can see rust as soon as 2 days,… but letter calls for maximum of 30 days (in reasonably dry environment) without taking further action
It calls for vapor phase corrosion inhibititor, etc. (called Vci in letter now called vcpi at spruce) If I know I will down for a while I put this in and fly before it sits for a while.
Wallace & Marietta Goodloe
9A -QB
N211LV
Phase 2 has started!
Thanksgiving time, is dues time for us
Old 03-16-2023, 10:36 AM
PilotjohnS PilotjohnS is offline
Default in the future
In the future, when we are all using unleaded avgas, is there a better engine oil one could use that would allow longer down time between flights?
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2023, worth every penny
RV9A- Status:
99% done, 1% left to go
To Go: wing mounting, wing tips, move to airport
www.pilotjohnsrv9.blogspot.com
Old 03-17-2023, 12:34 AM
ronrapp's Avatar
Just did an annual inspection on a pristine Piper Archer that's hangared in a well-insulated heated floor hanger that is temperature controlled year round. 22 hours on the airplane last year. Cylinders were full of rust. It's the acids and moisture in the oil that do harm. Not the environment.
If you say so. I'm just a pilot, and about as far from an A&P as one can get.
I sometimes wonder if hours flown, by itself, always tell the whole story. Would flying 30 minutes every weekend have the same result as flying 22 hours the first month and then sitting for 11 continuous months?
Do airplane engines that live in Arizona suffer the same corrosion as those that live in coastal Florida, given the same amount and frequency of use?
Old 03-17-2023, 07:43 AM
von_flyer's Avatar
von_flyer von_flyer is offline
Default Dehydration
I think engine dehydration is a valuable tool in preventing engine damage from moisture during sit times and even short term down time. Using a temperature and humidity data logger I documented the effect of dehydration on a Lycoming O-360. While this is relative to crankcase environment only, cylinder dehydration is a more difficult problem to solve. My data can be found here. I use dehydration between all flights not just for long term storage. EAA recently had a Webinar talking about dehydration that had some interesting information on the topic and can be found here.
John von Linsowe
Michigan
RV-7 - flying
Cessna 140 - flying
Drifter - project
B1-RD - flying
