w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 03-14-2023, 06:37 PM
David Z David Z is offline
Originally Posted by fl-mike View Post
Structural pan heads. You'll never notice the cosmetics vs C/S after completion. Just put a screw every place there was a rivet.
This is what I did.
RV8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage assembly, it's a riveting job!
83126
Dash 8 day job is financing the RV8
Donation till September 2023
Old 03-14-2023, 08:43 PM
scsmith scsmith is offline
+2. Thats what I would do too. Stick with 0.040" and use pan heads.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 725
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2022
Old 03-14-2023, 09:38 PM
bmellis11 bmellis11 is offline
Originally Posted by David Z View Post
This is what I did.
Thanks guys. I'm using AN515-8R8's right now and I'm not crazy about the look. If I can't change my mind on that point, do you think there's any structural concerns going with a thicker cover plate with countersunk screw holes and using a screw like an AN509?
Ben Ellis
RV-8 build in progress
Build Log
Old 03-15-2023, 12:54 AM
Double check if 0.063" is thick enough to countersink for #8 before you go to the trouble. If it is, then structurally it is fine. Just heavier with that thick plate.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
Hobbs 725
also
Old 03-16-2023, 09:49 AM
A plate thick enough to accept a #8 screw countersink would also have an unusual appearance to it. IIRC, the head height for that screw is 0.072", so it would become a very thick plate, 0.080 or more.
RV8
Wings mostly done
83126
Old 03-16-2023, 12:59 PM
Do you recall where you can find the chart for minimum thickness for each screw type? I looked through my books and couldn't find anything other than a recommendation to go no deeper than 2/3rds of the sheet thickness and to leave a minimum of 0.02" beneath the countersink.
Ben Ellis
Build Log
Old 03-16-2023, 02:14 PM
I just measured an AN509-832 and the head is about 0.077 tall.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
Hobbs 725
also
