w/a Donation
VAF on Twitter:
@VansAirForceNet
  #21
Old 02-20-2023, 04:48 AM
Tooch Tooch is offline
Went years using a wing jack for my RV's then I bought these and will never go back.
http://www.wintermotorsports.com/jackpoints
Old 02-20-2023, 06:33 AM
RicoB's Avatar
RicoB RicoB is offline
I also Use the RV Jack Points ( mentioned above) Best thing ever. easy and super safe.
Rico Burgos
2018- RV9a at AZ82 and KWHP
1959- C-150 at KMOD (Sold)
https://www.imdb.com/name/nm3018529
2022 dues PAID
Old 02-20-2023, 06:39 AM
Default Motorcycle lift entire plane
This isnt a wing jack but worked great for me when I was working on my brakes and wheel pants. It is a HF motorcycle life with a wood box. It lifts all 3 wheels off the ground if you get it balanced properly. It is not stable enough to get in the plane but plenty to work on the wheels.
Click image for larger version
ID:	38599  Click image for larger version
ID:	38600  Click image for larger version
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
2023
Old 02-20-2023, 06:56 AM
MacCool's Avatar
MacCool MacCool is offline
I had my mechanic put some of those on too at my last CI, primarily for flats away from home. I haven't used them yet, but they're certainly nicely designed and well-executed.
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
Dual Pmags
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
Old 02-20-2023, 03:55 PM
BillL's Avatar
BillL BillL is online now
Originally Posted by MacCool View Post
I made a couple of these, and used some smoothed-off grade 8 carriage bolts in the wing tie-down mounts as jack points.
Mac - are the those tabs welded to the jack reservoir can?
Bill
RV-7
Old 02-20-2023, 06:46 PM
MacCool's Avatar
Just bolted. My A&P put them on when he did the brake pads. No big deal, he tells me.
Name:	Screenshot 2023-02-20 at 7.41.30 PM.png
ID:	38657  Click image for larger version
Name:	Screenshot 2023-02-20 at 7.44.48 PM.png
ID:	38658  Click image for larger version
Name:	Screenshot 2023-02-20 at 7.45.13 PM.png
Dual Pmags
IFR equipped
Old 02-21-2023, 07:19 AM
BillL's Avatar
These tabs, Mac - - it is a little fuzzy when zoomed but can not firmly say if that is a sleeve or welded to the jack. Sorry, I responded to a 2021 post.
Name:	Screenshot 2023-02-21 at 8.15.52 AM.png
Bill
RV-7
Old 02-21-2023, 08:49 AM
MacCool's Avatar
Attachment 38670
Sorry, I misunderstood that you were talking about the wing jack. I think the image you're referring to is one I had copied from a Kitplanes article. Attached are the ones that I built. The upper ring is a sleeve that slips over the jack body and has 4 tabs welded to it, each with a hole for the 4 support arms.
One caveat....the bases of those jacks are not identical dimensions, one to the other. I put tabs on the bases so I could remove the whole jack from the assembly and placed the tabs on the base on one in exactly the same place as the other, and the second jack did not quite fit....needed a little help from a ball pein hammer
ID:	38672  Click image for larger version
Name:	Screenshot 2023-02-21 at 9.40.33 AM.jpg
ID:	38673  Click image for larger version
Name:	Screenshot 2023-02-21 at 9.40.57 AM.jpg
Dual Pmags
IFR equipped
