Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
03-18-2023, 05:08 PM
Man I know this is an old thread but I'm struggling with making these rudder pedal linkages.
Thank you for the Thingiverse link, I'm going to take that and the Van's drawings up to a local fabricator tomorrow to see if he can make it happen.
I tried using the local FBO's Jump Shear and it barely made an indentation in the metal.
Building an RV10 at KCOI
2023 VAF Dues Paid
03-18-2023, 06:28 PM
Doesn't Van's supply a strip of steel for the linkages? All you have to do is cut to length, round the edges, and drill 'em. A hacksaw, a file, and a drill should be the only tools required.
Now, if you're hacking them out of a sheet, that's another issue.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019? (actually 2022) RV-10 N46BX
03-19-2023, 06:18 PM
What Kyle said.
Or just go to HD or Lowe’s and buy a strip of metal the correct width and cut off the correct lengths.I have done this and it works great.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
Multiple RV builder currently flying
RV3B & Legend Cub
03-19-2023, 06:49 PM
The most common stomp shears max out at 16g which is .059 , mild steel, not 4130.
You might check the FBO”s shear as the blade probably took a pretty big hit.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
03-19-2023, 06:52 PM
Originally Posted by sf3543
What Kyle said.
They have 4130 ?
Bucker Jungmann
RV1 - Proud Pilot.
03-19-2023, 07:08 PM
Links
Vans has lots of choices
Link
Link
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
03-20-2023, 05:46 AM
My Van's supplied links with the RV-14 kit were not long enough if you put the rudder bar in the most forward holes. I made new ones using 4130 sheet. Ended up using several Dremel cut off wheels.
Glenn Martin
Windsor, Ontario
1941 Tiger Moth
2017 Waco YMF-5
RV-14 Kit # 140694 - First Flight June 22, 2021
2023 Dues Paid
03-20-2023, 06:26 AM
I got some 4130 strips from Spruce. They make good links and .061" is perfect for engine brackets like the factory. Hack saw and bench grinder to round the ends - keep the temps in control. If it quenches hardness will result.
Bill
RV-7
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
