w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 03-13-2023, 12:48 PM
Funguy's Avatar
Funguy Funguy is offline
Originally Posted by decathlon737 View Post
Here you go Larry. I like the fact that it doesn't have padding or glue to off gas during a fire event.
https://www.mcmaster.com/aluminum-honeycomb-panels/
How do you cut that stuff?
Cheers, Sean
RV6, Flying C-GOFG
CLA4 - Holland Landing
Toronto ON
Donated to December 2023
Old 03-13-2023, 02:40 PM
decathlon737's Avatar
decathlon737 decathlon737 is offline
Cuts easily with a bandsaw.
Bill Woods
RV8 sold 180 hrs. of pure joy
(Nov 2018) Bought 7A Tip up
project, converting to tailwheel
slider (just because)
Thunderbolt YIO390
Hartzell BA
Steinair Panel (WOW)
Old 03-14-2023, 09:31 AM
kaweeka kaweeka is offline
Which specific size panel did you order?
David
RV-9A N435KR, Vans calendar March 2018
LIO 320 B1A, Dual LS Plasma III, AFP injection
G3x touch
Roseville, Ca
Old 03-14-2023, 09:45 AM
3/4 thick will get you same height as angle in floor.
Bill Woods
Thunderbolt YIO390
Hartzell BA
Old 03-14-2023, 06:31 PM
hoyden hoyden is offline
I plan to run wiring and static/pitot/AOA lines along the left side from the spar forward to a convenient place and then up into the instrument panel. Do any carpet systems allow for a channel in the foam to act as a sort-of conduit?
RV-6 IO-360, CS
RV-9 QB under construction
Old 03-14-2023, 08:33 PM
The whole assembly is glued together. Bottom skin bonded to the core, top skin bonded to the core. The glue used is often a thermoplastic adhesive, so if it gets very hot (don't know how hot it needs) it could debond.
Dave
Old 03-14-2023, 08:50 PM
dpansier's Avatar
dpansier dpansier is offline
Originally Posted by Ross7A-builder View Post
What have other builders done for additional flooring, other than the outer skin and stiffeners, under the rudder pedals? Looks like it could use something to avoid outer skin dents and possibly add insulation.
I used 1/8” Baltic Plywood with a few 3/4” square Balsa blocks spaced under the foot stress areas. The Plywood was cut to shape and fit tightly, a small cord on the rear end allows the boards to be lifted out.
Don Pansier
Green Bay, WI (GRB)
RV-7
Antennas for Experimental Aircraft
www.deltapopaviation.com
Old 03-15-2023, 08:14 AM
cgeyman's Avatar
cgeyman cgeyman is offline
Default Aluminumized fiberglass
I use thermal heat barrier. Thin fiberglass with aluminum sheeting. It is peel and stick, cuts with scissors and easy to keep clean. 40$ on Amazon.comes in various sizes.
