GNS 480 Connection to Skyview
RV-4
Hello All
I'm in the process of installing a GNS 480 with interfacing with a Dynon Skyview and I was wondering if there is someone here who may have done the same and will have the right set up sequence for the ARINC & Serial setting for the 480??
I've tried a couple different set up as suggested by other users but so far I don't have much success in getting them to talk to each other..:(
I'm using Serial port 2 from the Skyview to the 480 Serial port 2...The TX-RX line are connected like they should
Any help will be appreciated
Bruno
[email protected]
