BLUF: Automotive alternator was slow to come online at idle RPMs, but rock solid once it was up. I later discovered it may be directly tied to a minimum crank RPM. My previous experience with this setup did not have a minimum RPM for positive charge; this behavior is new and I’m not sure why.
I had an issue I hadn’t encountered before on my flight today. I started the engine as normal with the alternator switch off. Once started, I turned the alternator switch on and nothing happened. The voltage did not change from what was supplied to the bus with just the battery (approximately 12.5v). After cycling the field breaker and the switch a few times each, eventually the voltage came up to 14.9 and then slowly went down as the battery charged from the start. Although I gave it some time between each action, I could not positively identify if either action caused it to successfully come up. Engine RPM was just above 1100 this whole time. I thought perhaps the alternator or voltage regulator had just been cold soaked and I taxi’d to the fuel pump after letting the engine begin coming up to temp.
After I filled up and started again, same thing. Just as I was turning to taxi back to my hangar the voltage came up appeared steady. I opted to take the plane for a lap in the pattern to see what it did. I ended up flying for almost 2 hours and the voltage was steady the entire time. After I landed, the alternator appeared to drop off again as I taxi’d in at about 950 RPM. In front of the hangar I advanced the throttle to achieve 1200 RPM and the voltage came up again.
In my past experience with the plane the alternator has not been noticeably sensitive to RPM once it was turned on. Ambient temperature at the time was about 50*F on the ground, but it’s been in the 20s at night for the past several days. The alternator is an older automotive brand (Mitsubishi I think, I’ll have to double check) in a belt driven configuration off the flywheel.
I can gather more information as needed on the external regulator and the alternator if needed, but since the operating concepts should be the same for any alternator I’m wondering if anyone has some insight into what’s going on here. Is it talking to me?
