drone_pilot
I did some searches but couldn't find anything on the topic. I probably need to expand my vocabulary.
Do any of you use a pressure washer to clean your engine during condition inspection? If so, what cleaning solution are you using to clean it? I've been using Varsol (air compressor delivery) but looking to see if there is anything to use in a pressure washer that'd be as effective and less smelly in getting rid of the oil residue and general crud buildup.
