Keep VAF
Going
10-05-2020, 11:09 PM
Looking to rent or borrow resurfacing grinder for cylinder
All,
I ran into an issue on my non RV aircraft. The exhaust port has eroded and can no longer seal between the gasket and the exhaust. I found tan powder on my spark plug and did a bubble check to comfirm.
My local A&P said to try to find a tool and do it on the plane without removing the cylinder. I don't want to spend this much money and only use the tool once.
I called this company and they no longer make the tool. http://www.widell.com/old_wid/pneuport.htm
Found one similar at spruce but dang!!!!!!! at least $700 by the time it gets to me.
https://www.aircraftspruce.com/catal...surfactool.php
Thanks for any help you can provide.
Axel
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
10-06-2020, 04:51 PM
There's a rental available from a company in Wisconsin I believe it is. I used it on a 172 cylinder. It worked alright, not as good as one I had used a few years back though but it did get the job done. I am trying to find the receipt and contact info in my inbox but its proving difficult … standby
edit: found it …
Joyce Anderson
Ru Lon Aviation, Inc.
230 James St. Suite C
Wales, WI 53183
800.888.6002
Looks like this https://www.tennesseeaircraft.net/wp...2015-pic-1.jpg
Lancair 320
RV4
10-06-2020, 05:37 PM
Originally Posted by tgibbs
edit: found it …
Joyce Anderson
Wales, WI 53183
800.888.6002
[/url]
Will give them a call. Thank you.
Axel
10-07-2020, 10:42 AM
They no longer carry it.
Axel
10-07-2020, 11:49 AM
A little birdie told me this stuff might be helpful...
https://smile.amazon.com/J-B-Weld-37...2089269&sr=8-7
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
10-07-2020, 05:23 PM
There used to be a place called hangartoolbox.com that rented tools, unfortunately it seems to be gone now. Back in the 2013 timeframe I rented an Aerogrinder U-92 from them. It worked great on an old O-320. There appears to be one on ebay for sale now, looks rather complete but I couldn't say for sure. If you're up for an experiment:
https://www.ebay.com/itm/Aero-Grinde...12169#viTabs_0
For the mods: I'm not in any way affiliated with this ebay link, just trying to help Axel out. If you need to, feel free to delete.
Kurt W.
RV9A
FLYING!!!
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
