Old 04-29-2020, 06:58 AM
Kooshball Kooshball is offline
Default Sealing carbon fiber plenum with RTV?
I after the annual is done on the -4, I am planning to improve the sealing of the carbon fiber plenum. We have one made of several pieces of overlapped, dull carbon fiber; not a shiny 1-piece plenum. The areas of overlap don?t have any gaskets; just carbon sheet on sheet and I planned to apply a bead of high temp RTV during reassembly to seal it up a bit.
Are there any reaction / interaction issues with silicone RTV being applied to dull carbon fiber sheets? I mention dull since the glossy, finish grade carbon sheets likely have a thick enough layer of epoxy where the carbon isn?t really in play for such a situation.
Thx
Old 04-29-2020, 07:46 AM
Southern Pete Southern Pete is offline
Using RTV will mean you will not be able to repair the baffling ever - the resin will not stick to a surface that has seen a silicone based product. Good quality duct tape might act as a thin gasket of you are worried about sealing. Doesn't matter if the carbon has a layer of epoxy giving it a shine, the silicone will penetrate and prevent anything bonding. If duct tape is too thin how about a strip of cork?
Old 04-29-2020, 08:15 AM
SeanB's Avatar
SeanB SeanB is offline
How about UHMW tape? Same as used on the flaps. Flyboy Accessories has the good stuff that does not "yellow".
https://www.flyboyaccessories.com/Pa...ilm-p/2301.htm
SEAN BLAIR V7
Colorado Springs, CO
http://www.mykitlog.com/sblair
2020 VAF SUPPORTER
Old 04-29-2020, 12:37 PM
RVDan RVDan is offline
I?d stay away from silicone for the reason mentioned. How about a thin foam tape? The foam would take up any gap up to the thickness of the tape.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Retired Aerospace Engineer and A&P/IA
Old 04-29-2020, 02:15 PM
AX-O's Avatar
AX-O AX-O is offline
Thx
I have been using this between my carbon fiber plenum and the aluminum baffles. so far it is working well.
https://www.mcmaster.com/85925K205
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 04-29-2020, 02:46 PM
Gusmax Gusmax is offline
There are all sorts of paintable caulk/sealants at the hardware store. PRC sealant (fuel tank or fairing sealant) is very paintable also.
Phil Kite
F4 Raider project with RV-8 wings and tail
Old 05-01-2020, 06:25 AM
Thx for the suggestions folks.
