Go Back   VAF Forums > Model Specific > RV-15
  #201
Old 08-30-2021, 09:52 PM
jcarne's Avatar
jcarne jcarne is offline
Originally Posted by grubbat View Post
and that magical 55mph survivability wall
Is this a thing? I have never heard of it.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 08-30-2021, 11:25 PM
gasman gasman is offline
You could crash your aircraft at 55 or less and as long as you don't hit something that brings you to a sudden stop, you should survive.........
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
Old 08-31-2021, 06:14 AM
FlyNSoCal FlyNSoCal is offline
Default Crashworthiness
Interesting theory. Your odds of survival are certainly better at lower impact speeds. Depending on how rapid the deceleration, structure still plays a big part. If Vans decides to put a full wing spar right in front of the two front occupant's heads, that 55 mph could still leave a mark. If they put the fuel tank above your legs like Sonex, that could get interesting as well.
Here in congested Southern California, good luck finding wide open spaces to do a gradual rollout from 55 to 0 mph. Nevertheless, I'd rather do it at 55 mph than 63 mph in my current airplane.
Old 08-31-2021, 09:28 PM
jcarne's Avatar
Ya I know slower is better but I didn't know if that 55 number was statistically significant or not.
Jereme Carne
PPL
Old 08-31-2021, 11:07 PM
Van's won't do that. It will be above, behind or placed where your head will not hit it. IF you flip, you will want that spar there. Your chance of walking away, and even flying the airplane out are very good.
Old 09-01-2021, 06:28 AM
grubbat's Avatar
grubbat grubbat is offline
Default Curve
If I recall, Vans had a graph with a curve on it that showed the relationship between speed and survivability, using data from I guess years of information. I donít think the point was the actual 55 number, but rather the desire to try and keep the stall speed on the lower end of the spectrum. I remember looking at the White Lightening and Lancair stalls speeds on the graph and it was humbling. The survivability curve got exponentially worse above 55 to 60mph. One thing that stands out in my mind was the amount of concern that Van gave this when he was designing his planes.
Craig
RV-3 Sold
RV-4 Sold
1968 Twin Comanche - Sold
RV-6a Sold
1965 Comanche 260 - Sold
RV-9 Built and Flying
600A Aerostar - Sold and regretted
2000 Maule MXT-7 Project
1965 Maule M4 Bushwacker projectÖ till RV-15 shows up
Old 09-01-2021, 07:38 AM
rocketman1988 rocketman1988 is offline
Default yep...
KE=1/2mV^2, so an increasing the speed increases KE exponentially...
Bob
Aerospace Engineer '88
RV-10
N464RL
Dues+ Paid 2020,...Thanks DR+
Old 09-02-2021, 05:41 PM
jcarne's Avatar
I will have to look for that graph. Would like to see where the -10 falls on the curve.
Jereme Carne
PPL
Old 09-04-2021, 07:27 PM
ssturges ssturges is offline
My need is for C182/206 version of an RV10 high wing.
Tricycle
4 seats
6 cylinder rv10 performance
upgrade path for a turbo, mid teens cruise
Easy to get in and out of
A big baggage door to rear seats and baggage area
Option for installing a BRS chute
The C206s are in very high demand for back country work. As they say the professionals choice.
Old 09-05-2021, 11:05 AM
mfleming's Avatar
mfleming mfleming is offline
Vans just posted a teaser on FB with the the RV-15 covered up in the background
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring and Avionics harness completed 9/2/2021
FWF Started 9/3/2021
Donated for 2021 and so should you
