Canopy side skirts
BGordon
Howdy everyone, just starting the side skirts for my slider 7 and was wondering about the C-660. i can't find them but I do have two pieces of AS3-032x4 9/16x32. I assume they need to be fabricated but wanted to ask before I start drilling.
B
That is it. I don't recall if mine are labeled or not but they are the only two pieces in the finishing kit that fit that location.
The size is close, based on the drawing, but some trimming will be required.
Canopy skirt
The two sheets AS3-032x4 9/16x32' are the correct parts that you need. This was the only identification that was on my parts and that is the part number that Van's lists them under on their web store.
Remember to remove the half inch of material at the bottom front of the skirt as this will provide clearance to the fuselage when you slide the canopy back.
Regards,
Gordon
