Go Back   VAF Forums > Main > VAF Classifieds (posts in here deleted after 30 days)
Old 10-14-2021, 03:57 AM
Michael Wellenzohn's Avatar
Michael Wellenzohn Michael Wellenzohn is offline
Default Looking for standard oil filter adapter (straight) for IO-540 D4A5
Attachment 17061Hi,
I am on a project to add an standby alternator to my TMX-IO-540 which has the Mattituck 90 oilfilter adapter with a 2,5 in spacer installed.
It might be the easiest and cheapest solution to just go back to the standard straight oil filter adapter.
Question 1:
does someone know if the parts in the attached drawing can be ordered as a kit?
Question 2:
Did someone do the conversion and has the original one for sale?
Question 3:
Can I use the existing THERMOSTATIC OIL COOLER BYPASS VALVES (blue) or are there different models for the 90 or the standard oil filter adapter?
Michael
Click image for larger version
Name:	Oil filter IO-540 D4A5.png
RV-10 builder (flying)
#40511
Switzerland
Osh?18 OWW volunteer
Countries HB-YNN has visited:
🇨🇭 Switzerland, 🇩🇪 Germany, 🇦🇹 Austria, 🇮🇹 Italy, 🇭🇷 Croatia, 🇫🇷 France, 🇪🇸 Spain, 🇵🇹 Portugal, 🇸🇮 Slovenia, 🇭🇺 Hungary, 🇷🇴 Romania, 🇷🇸 Serbia, 🇨🇿 Czech Republic
www.wellenzohn.net
First flight Video: https://youtu.be/X7EQ81C3xSA
Old 10-14-2021, 06:46 AM
togaflyer togaflyer is offline
Michael, I installed an Airwolf remote filter setup. On my RV 10 the mount is set on the far right side of the fire wall. I have a standby alternator installed. Good access to the standby alternator and changing out the oil filter is very easy.
Old 10-14-2021, 08:02 AM
Did you buy your engine with the Airwolf remote filter or do you have the original one now available?
#40511
Switzerland
www.wellenzohn.net
Old 10-14-2021, 11:55 AM
I bought mine and installed it in 2017. Engine had not been mounted yet, but not much more hassle with the engine mounted. Just more reaching.
