Old 10-10-2021, 07:25 PM
Prepperpilot's Avatar
Prepperpilot Prepperpilot is offline
Default WTB Smoke Oil in Central Ohio
Hello everyone. New RV8 owner here.
My airplane can with smoke system, well it ran out.
Anyone know where I can source locally without buying 55gallon drum ?
Chris
Old 10-10-2021, 09:11 PM
rleffler's Avatar
rleffler rleffler is offline
Chris
Reach out to jseavolt, he has a RV-8 at DLZ. I think he bought a drum.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 10-11-2021, 11:12 AM
N729LS's Avatar
N729LS N729LS is offline
I got tired of smoke oi prices, even from the local Copperstate Petroleum. I ended up buying a case of 4 gallons of CSP contrete form release oil at $14/gallon. I find the single gallon jugs easier to work with, but it is also available in 5-gal pails at $54 ($13.50/gal). CSP smoke oil is $85 for the 5-gal pail ($17/gal). The tech at CSP said the formula is "very similar" to CSP aviation smoke oil.
My experience is that it gives a very good plume, but maybe (?) leaves a little more on the bottom of the plane. In the long run, since I go through only about 10 gal/year, the cost difference is not significant, but the form oil is much easier to find.
FWIW,
Andy
Andy Elliott, CFI, RV-8, N303RV
Flight Reviews, Dynamic Prop Balancing
KFFZ, Mesa, AZ
2021 Dues Paid
Old 10-11-2021, 01:40 PM
g zero g zero is online now
Default Smoke oil
I go to the local feed store Ö.Mineral Oil Light , keeps your livestock flowing smoothly. Itís the same food grade stuff as baby oil and laxative oil for humans at Walmart . Great white harmless smoke
Rv8
N 666 TA
First Flight 2-3-2015 🚀
Old 10-11-2021, 07:21 PM
Thank you for pointing me in a good direction.
Old 10-12-2021, 05:55 AM
ty1295 ty1295 is offline
We keep it at Louisville Ky Bowman Field KLOU for around $11 Gallon. Mostly for our own local formation use, but being we buy 4 barrells at a time for shipping, we will help others also.
smokeonaviation@gmail.com
Jeff Scott
RV9A First Flight 9/30/19
