Old 09-29-2021, 09:19 PM
andresmith76@hotmail.com andresmith76@hotmail.com is offline
Originally Posted by N804RV View Post
Question about using illuminated rocker switches with VP-X:
If you use VP-X or Advanced Systems digital breakers, the switches only provide a ground input to the box, there's no current through the switch.
So in this case, do you have to provide a discreet voltage to light up the switch rocker for night illumination. And, for the dependent "ON" indication, where does that power come from?
Yes, you must provide a 12v source to the LED/lamp to illuminate. I used my plane's main buss voltage protected by a circuit breaker. A Double Pole/Single Throw (DPST) switch would work in your example - 1 pole to switch & provide power to the LED and the other pole to switch & ground your circuit.
Read this to learn more about Independent & Dependent switch lamps:
https://rockerswitchpros.com/differe...pendent-lamps/
Old 09-30-2021, 06:07 AM
Pip Pip is offline
Default Info
@andresmith76 Good info.
Old 09-30-2021, 06:22 AM
mountainride mountainride is offline
I used the carling rockers and VPX. I didn't run a dimmer at first and the switch lights were way too bright. I rewired through a dimmer a year into it and now its perfect! I am just switching ground so not worried about the switch but there is a lot of plastic. I wouldn't want to run any amperage through the carling rockers.
-Jason
RV-14 N303XC : Flying
Old 10-06-2021, 10:18 AM
sumitku sumitku is offline
These are the rockers used on Cirrus...
https://www.ckswitches.com/media/1443/df.pdf
RV-10 Emp Kit
Started Feb 1, 2015
kumarrv10.wordpress.com
Old 10-06-2021, 01:37 PM
GrinchF16 GrinchF16 is offline
Default Installed
Originally Posted by Freemasm View Post
Mel
I have some Carling rocker switches that were made for me. Certified style with threaded terminals and threaded mounting. Carling doesn’t certify their switches (unless has recently changed). They have nice feeling actions. Some OEMs like Cessna, Piper, Mooney utilized them under some aircraft TCs. Anyway, if you’re interested, PM me.
Do you have these switches installed? If so, pictures perhaps?
Brian
Old 10-06-2021, 01:57 PM
Freemasm Freemasm is online now
Default Not specifically, but
Not specific switch pix but a couple closeups from a panel upgrade; plus a naked one. They engrave nicely. Have engineering data crops if desired.
I had these made as they're the closest dims to the Rocker breakers (bottom right of pic 2) common to that vintage. You've probably flipped one in your past. The Cessna split Alt/Master switches are the same family.
You can PM me and reach out through the forum here.
Click image for larger version
Name:	carling switch 1.jpg
ID:	16837  Click image for larger version
Name:	carling switch 2.jpg
ID:	16838  Click image for larger version
Name:	Carling switch 3.jpg
Old 10-06-2021, 05:39 PM
gasman gasman is offline
Originally Posted by Mel View Post
These are not DC rated.
I used a non DC rated switch in a DC application that was switched on and off thirty to forty times a day 5 days a week for over 10 years without one failure. Purchased at ACE hardware.
In a HIGH amp draw situation, I may use DC switch.
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
Old 10-06-2021, 06:20 PM
Labeled versus rated. Only speaking for the ones I’ve posted. Labeled with the AC rating obviously. Eng drawing and product catalog list the 15 amp DC rating.
From my experience with industrial grade equipment (not aerospace), AC rated devices can have real issues with DC. Not always related to power throughput as I would have thought. Not unusual (probably typical) that the issue is with the “break” versus the “make”. The potential never crosses null so contacts can stay closed when the opposite is desired/actuated. More true in relays and instrument switches from my experience than a manual switches but certainly possible and probably more likely the more miniaturized something is. There’s also contact erosion down the road. Guess my real point is to use devices I.A.W. the OEM’s rating. I’m ME, not EE so I rely a lot on vendor literature and their reps for my info. Long a$$ rationalization over, sorry.
Old 10-14-2021, 07:02 AM
rvn817j's Avatar
rvn817j rvn817j is offline
Default Electronic Goldmine
Every once in awhile, this site has some interesting deals (buy extras as this is a clearance site) - https://www.goldmine-elec-products.c...521db-60318049
Jay at KLVN
RV8 N817J
Airworthiness Cert. 10/99
Old 10-14-2021, 12:33 PM
Mel's Avatar
Mel Mel is online now
Default Found.....
I found the switches I need. Thanks for all the help. Most switches referenced here are to tall for my space.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
