Old 09-29-2021, 05:38 PM
Mel's Avatar
Mel Mel is online now
Default Looking for decently priced Rocker Switches...FOUND...
Toggle switches are in the $10-15 range. Rocker switches I find seem to be in the $60-70 range.
What am I missing.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-29-2021, 05:53 PM
sumitku sumitku is online now
I’m thinking of using these…
https://www.digikey.com/en/products/...LKESGRN/251347
RV-10 Emp Kit
Started Feb 1, 2015
kumarrv10.wordpress.com
Old 09-29-2021, 05:58 PM
Mel's Avatar
Originally Posted by sumitku View Post
These are not DC rated.
Old 09-29-2021, 06:09 PM
Walt's Avatar
Walt Walt is offline
What am I missing.
The Honeywell toggles I use avg in the $30-$50 range, come on over to the dark side Mel and get a real switch
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
True.
These are…
https://www.digikey.com/en/products/...-2-GL/11492761
RV-10 Emp Kit
Started Feb 1, 2015
Old 09-29-2021, 06:11 PM
GeoffP's Avatar
GeoffP GeoffP is offline
Default rockerswitchpros.com
These guys sell Carling rocker switches & do custom actuators. 12V 20A 50k cycles rated. Can get them with indicator lights built-in if desired. The con's are they're fairly large and difficult to lock or protect from inadvertent contact.
RV-9, Empennage and Wings about done, Fuselage taking shape.
Old 09-29-2021, 07:57 PM
andresmith76@hotmail.com andresmith76@hotmail.com is offline
What am I missing.
Get the Carling Rocker switch bodies here:
https://spemco.com/v-series-rocker-switch-base/
And the custom actuators here:
https://rockerswitchpros.com/switch-actuators/
Rocker Switch Pros also have very good tutorials on Carling switches:
https://rockerswitchpros.com/blog/
Andre'
Old 09-29-2021, 08:18 PM
N804RV's Avatar
N804RV N804RV is offline
Question about using illuminated rocker switches with VP-X:
If you use VP-X or Advanced Systems digital breakers, the switches only provide a ground input to the box, there's no current through the switch.
So in this case, do you have to provide a discreet voltage to light up the switch rocker for night illumination. And, for the dependent "ON" indication, where does that power come from?
Ken W.
Mount Vernon, WA
2021 VAF Supporter
Old 09-29-2021, 08:54 PM
Freemasm Freemasm is offline
Default I have some
Mel
I have some Carling rocker switches that were made for me. Certified style with threaded terminals and threaded mounting. Carling doesn’t certify their switches (unless has recently changed). They have nice feeling actions. Some OEMs like Cessna, Piper, Mooney utilized them under some aircraft TCs. Anyway, if you’re interested, PM me.
Old 09-29-2021, 09:15 PM
I have installed a bunch of these in some pretty nice boats. I may change my panel layout and switch to something like this. Not sure if you could get them label etched with what I want.
https://www.amazon.com/Switches-Wate...s%2C178&sr=8-4
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
