  #21
Old 10-03-2021, 06:54 PM
Jesse23 Jesse23 is offline
Thanks for all the great input. Definitely need to pay more attention to proper tire inflation, but such a PIA, with a straight valve stem that points directly inward to the axle. Havenít come up with a way to inflate wo taking pants off, even with a removable insp cover.
Old 10-04-2021, 03:52 AM
rleffler's Avatar
rleffler rleffler is offline
The solution is easy. Replace your tubes with those that have a ninety degree valve stem. Drill a 3/4Ē hole in your wheel pant that aligns with your stem. You can find a cap for the hole at just about any hardware store.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 10-04-2021, 06:11 AM
Thanks Bob -
Can you tell where I can find this gem 15x6.00x6 90 deg? I have not been able to procure anywhere. I have the cutout and plug in place.
Old 10-04-2021, 06:22 AM
rleffler's Avatar
Thanks Bob -
Desser and Spruce have them in stock from multiple manufacturers. Desser has better pricing. I’m about to pull the trigger on three new tubes and a tire for the nose wheel. Desser was about $200 less expensive than Spruce. But Spruce does some price matching.
Michelin Airstop 15-6.00 x 6 tube w/ 90 stem. 092-501-0
https://shop.desser.com/15x6.00-6-mi...detail/323625/. This is a straight stem tube, not a 90. Dresser doesn’t have a 90 on their web page. Just discovered when talking to Spruce about price matching.
https://www.aircraftspruce.com/catal...chAviator2.php
Bob Leffler
Last edited by rleffler : 10-04-2021 at 10:34 AM. Reason: Correcting recommendation
Old 10-04-2021, 05:04 PM
Desser and Spruce have them in stock from multiple manufacturers. Desser has better pricing. Iím about to pull the trigger on three new tubes and a tire for the nose wheel. Desser was about $200 less expensive than Spruce. But Spruce does some price matching.
https://shop.desser.com/15x6.00-6-mi...detail/323625/. This is a straight stem tube, not a 90. Dresser doesnít have a 90 on their web page. Just discovered when talking to Spruce about price matching.
Thanks again Bob - $$$ Double the price of the straight valve - unbelievable, but is the way to go moving forward. Now, I can use the access hole as planned and checking pressure will be part of every pre-flight vs just looking at the tire under 1/2Ē of exposed tire under wheel pants.
