Old 09-27-2021, 07:31 PM
Deuelly Deuelly is offline
Default FOR SALE:Garmin GPS 175
I have a GPS 175 I purchased and never installed. I've only opened the box a couple time. It comes with the four foot wiring harness and the GPS antenna. Everything that was in the box when I received it from Aircraft Spruce is still there. Asking $4250+shipping.
Brandon
Click image for larger version
ID:	16408  Click image for larger version
ID:	16409  Click image for larger version
Old 09-27-2021, 07:35 PM
sinjin sinjin is offline
Default 4ft wiring harness
if you are interested in just selling the 4ft harness separate id like to buy that. $100 ?
Old 10-01-2021, 05:07 AM
PaulYardy PaulYardy is offline
Default Garmin GPS175
sent you a private message on this GPS175
Old 10-01-2021, 07:25 AM
Captain Avgas Captain Avgas is offline
Aircraft Spruce are selling the Garmin 175 new with full warranty for $4495. See here.
https://www.aircraftspruce.com/catal...ges/gps175.php
Youíre only as good as your last landing
Bob Barrow
RV7A
Old 10-01-2021, 03:58 PM
fasilpereira fasilpereira is offline
This price is for the Certified version. The experimental is $4683 with full warranty.
https://www.aircraftspruce.com/catal.../gps175exp.php
Fabricio
Old 10-01-2021, 09:17 PM
Fabricio
It's hard to comprehend why anyone would pay more for an "Experimental" unit than a unit that has an STC for over 700 certificated aircraft. Presumably they're the same hardware anyway.
At any rate, whatever price you see on Aircraft Spruce's website for avionics, you can always do better by shopping around.
Bob Barrow
RV7A
Old 10-02-2021, 05:07 AM
Tooch Tooch is offline
Default less money
The price at spruce includes the harness and so does the sellers. So you would save over 400 bucks with this deal. It is not more expensive than the certified version.
Why don't we just let the seller post his item without bugging in and steering others to better deal. In which this case would be false.
Old 10-02-2021, 05:28 AM
Richard Connell Richard Connell is offline
Perhaps before shooting your mouth off you should try ringing around and see what the wait time and cost is for one with a prewire / harness.
Please report back.
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 10-02-2021, 06:13 AM
Ralphieflies's Avatar
Ralphieflies Ralphieflies is offline
Its the same unit...Garmin does not make an "Experimental" GPS175...Please read the specs both are TSO'd....The Experimental portion is related to the pigtail...
Look at the picture of this unit for sale..It's TSO'd...
I had the same issue with buyers on my GTN650...Buyers assumed because it came out of a Vans RV it was an "Experimental" unit...Garmin does not make an "Experimental" GTN650 either...
Also in the past Garmin Dealers were not allowed to (or wouldn't) sell a unit without installing it unless it was for an Experimental Aircraft...Seems like that has changed somewhat...
2011 Vans RV9A N5926B
2019 Vans RV12 N38DR EAB...Phase 1 Completed 7/21...
2011 Vans RV12 N214LA ELSA...SOLD
Vans RV12 build in progress SN121020...Donated to Teen Aircraft Factory of Manasota
2009 Vans RV9A Slider N183FC-SOLD
Old 10-02-2021, 04:28 PM
Hello Guys!
Thank you for the clarification in regards to certified vs experimental. I knew that there was not an experimental version and I couldnít understand the reason for the additional price....
In regards to warranty, does anybody knows if it transferable? Some time ago I spoke with a GARMIN tech support engineer from Brazil and he told me that the warranty was limited to the original buyer, but Iím not totally sure about it.
Thank you,
Fabricio
