Old 09-20-2021, 09:16 AM
Sully73 Sully73 is offline
Default Painting my RV-4
I am getting ready for paint on my disassembled RV-4. I am really excited.
After some research, I have decided to use "Prekote" for the aluminum prep then an epoxy primer from PPG (CRE-121) then 2-3 coats of Single Stage Urethane paint from PPG (AUE360).
I will paint either a white or red base and later add vinyl decals for numbers and some decorations.
Question, how much primer and paint should I buy?
Any advice on my plan?
Thanks in advance.
Old 09-20-2021, 09:53 AM
94kb 94kb is offline
I used 1 gal of 1:1 epoxy, 1 gal of white, 1 gal of yellow and 2 qts of blue. I painted the RV4 in 2006 and the paint has held up well and the decals are ok but the paint can be polished and the decals will fade some. If it is not a difficult scheme I would recommend paint and no decals.
Ken
https://photos.app.goo.gl/KbWWsFHXENZLHCDCA
https://photos.app.goo.gl/acQZZ4EMGXWgXdan7
first photo 2006 second photo 2020
Kenneth Beene / Waco, Texas
RV-4 N63KB low wing
J-3 N2263M high wing
AS1 N777PJ bi wing
Cherokee N4217J
APRS WY0S
Old 09-20-2021, 10:16 AM
Wow, That is a beautiful RV-4 Good job and thanks for the good advice.
Old 09-20-2021, 11:55 AM
acam37's Avatar
acam37 acam37 is offline
After acid etch you should alodine before priming.
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
Old 09-20-2021, 12:57 PM
wirejock's Avatar
wirejock wirejock is offline
Default Alodine
I agree but stress proper PPE and collection of chems. I Alodined mine. It wasn't a pleasant process. I plan to vinyl wrap and wanted it protected under the vinyl.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 09-20-2021, 01:04 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
I suggest not doing this. A good epoxy primer and urethane top coat provides for a very durable finish.
Why alodine if there is nothing to gain?
Carl
Old 09-20-2021, 02:17 PM
snoop9erdog snoop9erdog is offline
Thanks in advance.
Where are you buying the PPG paint and Primer?
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
Worlds longest RV build...but getting there
Old 09-20-2021, 07:57 PM
AzAero AzAero is offline
No need to Alodine as Prekote is an alternative to the "Etch and Alodine" pretreatment process. If I recall it requires a thorough scotch brite scrub, rinse and prime as soon as thoroughly dry and even a final solvent wipe is discouraged.
RV-4 0360 CS Prop
Arizona Aeropainting
Custom Aircraft Painting
A&P
Old 09-20-2021, 09:01 PM
rmarshall234 rmarshall234 is offline
There you go...from a painting professional.
I've used Prekote with very good success as well. I think it was manufactured for Boeing and is the go-to-alternative to the previous harsh on your health and harsh on the environment processes.
Old 09-21-2021, 07:42 AM
"Precoat," that's a new one to me. What is it, how is it used, and who supplies it?
Sorry for the thread creep....
Dave
