Old 09-20-2021, 08:43 AM
John Tierney John Tierney is offline
Check for accessory brackets like your fire extinguisher holder.
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 09-20-2021, 12:49 PM
FinnFlyer FinnFlyer is offline
Again, check behind the panel. Isn't that the kind of screw that might be used on switches and switch/breakers?
Finn
N214FL RV-4 Mazda 13B Renesis First flight 20 Feb 2021
N46AZ RV3-B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
Old 09-20-2021, 01:22 PM
jclark jclark is offline
Default A VERY different thought ...
Originally Posted by craig.roser View Post
When upside down the other day this screw plinked on the canopy. When I turned upright it landed in my lap. I have looked and cannot find an empty hole, and I cannot find a similar screw.
Any ideas where this particular screw is used?
This looks VERY similar to the screws used in the EarthX batteries.
(Was just working with some.)
Do you have those? If so, have you been working on those lately? And further of so, are they in you cockpit?
Of course, I am assuming that if all the above is true you, dropped an EXTRA one as if one fell you you would have noticed.
Just an "out of the box" idea.
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 09-20-2021, 05:18 PM
Pdtofly Pdtofly is offline
Default Circuit Breakerís
I have a bunch of circuit breakers that an airline mechanic friend gave me. They uses screws like that.
Good luck in your search.
Old 09-20-2021, 09:15 PM
Steve Melton's Avatar
Steve Melton Steve Melton is online now
yeah, finding a loose screw will give you heartburn. understand the concern.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 09-21-2021, 03:56 AM
rzbill's Avatar
rzbill rzbill is offline
Are you the original builder.? You signature indicates no?
I ask because I replaced a large quantity of #8 screws in the cabin with these because they are very easy to drive with an electric screwdriver and a hex socket.
No need to hold pressure on a Phillips bit while in an uncomfortable contorted position.
Original builder could have done same.
Its a NAS1801-08-07 by the way. Spruce caries them.
Bill Pendergrass
ME/AE '82
Old 09-21-2021, 04:17 AM
fixnflyguy fixnflyguy is offline
Default CB ,Adel,or AVX
Very common screw in the heavy jet industry, most often for Adel clamps , grounding connections or Circuit Breaker terminals. The CB terminal screws are usually shorter # 6 or #8's. My bet is someone was trying to secure an Adel clamp and it went sailing into the abyss, as often happens. I have a zillion or more in my inventory..not a structural screw.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 09-21-2021, 06:17 AM
caryr's Avatar
caryr caryr is offline
It kinda looks like the screw that comes with 'threaded terminal' batteries.
They are usually 10mm socket head with a Phillips center.
Can't exactly tell from the picture the relative size.
Cary Rhodes
Taylorsville, Georgia
N203CR
Van's RV-7
First Flight April 2004
Old 09-21-2021, 11:10 AM
craig.roser's Avatar
craig.roser craig.roser is offline
It's a #8 screw. 1/4 inch hex head with Phillips.
Craig Roser
2022 Carbon Cub FX3 Amphibian Gerridae ON ORDER
2015 Gunter Malich RV8 El ZunZun
2005 Cessna C182T G1000 Alexandra
West Central Florida
Old 09-21-2021, 11:23 AM
rv6n6r's Avatar
rv6n6r rv6n6r is offline
Hey, I've been looking everywhere for that screw!
Randall Henderson
RV-6 / O-360 / CS, 1600+ hrs, 1st flight Sept. 1999
Outstanding Workmanship OSH 2000
Airport committee chair & AOPA ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Donated August 2021
