Old 09-01-2021, 11:35 PM
rapid_ascent rapid_ascent is offline
Default Where to Purchase Princeton Capacitive Converters
I've been trying to figure out where I can buy a set of the 2 point Princeton capacitive fuel sensor converters. ACS is showing the 5 point version, but I don't need those with my G3X system. I've emailed and left voicemail at Princeton Electronics, but no response. I heard that GRT sold them, but they responded that they no longer sell them. I think Vans used to sell them, but I didn't see them when I searched for them.
Any ideas on how best to proceed?
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 09-02-2021, 05:46 AM
KatanaPilot KatanaPilot is offline
Are you sure you need the converters? The GEA is compatible with capacitance probes like the Princeton. I think you need to provide ships power though, since the GEA power output is somewhat limited.
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2 (Honored to be Van's "Miss July" 2021)
RV-10 under construction at Synergy Air South
Old 09-02-2021, 05:51 AM
MS1095 MS1095 is offline
https://www.princeton-electronics.com/
08/26/2021
Princeton Electronics is currently re-organizing and will not be accepting any new orders at this time (with the exception of CP10A modules). Please check back soon for further updates.
Old 09-02-2021, 08:02 AM
Well that's not good news.
Anyone have a set of the 2 point converters sitting on a shelf somewhere that they aren't planning to use.
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
Old 09-02-2021, 08:23 AM
rocketman1988 rocketman1988 is online now
Default issue
I think that this is a misconception that many have.
The Princeton capacitance probes output 0-5v; for the Garmin setup, no converter is needed.
Princeton ALSO sells "converters" to change frequency output, from other manufacturers, into 0-5v output.
You also need to know that they recommend using ship power for the sensors. They said that the GEA24 does not have sufficient output to drive the sensor.
You may also be able to reset the 5 point sensor...
I spoke with Todd some time ago, and he sent me these supplemental instructions:
Multi Set-Point Supplemental Instructions
The multi set-point feature of the probe allows the selection of 1S, 2S and 5S modes.
1S (Calibrate Empty)
-The output will be 0 volts for empty and approximately 1.5 to 3.5 volts for full. -Used by Dynon and Advanced Flight EFIS Systems.
-Can be used by Grand Rapids Technologies EFIS.
-Has the advantage of not having to empty the tanks to calibrate the EFIS.
2S (Calibrate Empty and Full)
-The output will be 0 volts for empty and 5 volts for full. It is linear between the two. -For use with Grand Rapids Technologies and Chelton EFIS.
-Used with analog gauges and some EFIS that use a calibration table.
-Gives greater voltage range on the output.
5S (Calibrate Empty, 1⁄4, 1⁄2, 3⁄4, and Full)
-Used with analog gauges and some EFIS that use a calibration table. -For use with Grand Rapids Technologies and Chelton EFIS. -Linearizes the output for analog gauges.
-For an EFIS, enter a linear chart in the table.
-Gives greater voltage on the output.
Stratomaster Calibration
-The probe can be re-calibrated an unlimited number of times.
-The only calibration sequence for the Stratomaster version is empty.
-Calibration can be entered or restarted at any time.
-To enter calibration mode, hold the button down while turning on the power.
-The empty set point can take as long as 16 second. All other set points are less than 2 seconds. -Water affects the probe, giving it a reading of full. Water will not hurt the probe. The surface
tension of water will make it hard to be removed from the probe. Gently tapping the probe will help.
To Select the Set-Point Setting:
1. Power off the module.
2. Short the output (yellow wire) to ground.
3. Press and hold down button.
4. While holding down the button, turn power on.
5. After 10 seconds, the lights will turn off. Keep button pressed.
6. The left light will come on, then it will shift to middle, then to the right light and then all lights will light. It will repeat this continually until you let go of the button.
7. Release the button when the appropriate light is on.
8. Turn off the power and remove short to ground from the output.
Left Light = 1S
Middle Light = 2S
Right Light = 5S
Middle & Right Lights = Stratomaster
Knowing what I know now, If I build again, I will use the CiES sensors for fuel quantity...
Bob
Aerospace Engineer '88
RV-10
N464RL
Dues+ Paid 2020,...Thanks DR+
Old 09-02-2021, 08:27 AM
Bob, thanks for that info. I'll have to check with ACS on the 5 point units. I went back and took a closer look and it says special order so they may not have any stock. I'll give them a call though and see.
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
Old 09-02-2021, 08:45 AM
So Iíll ask again since I may be one of those who donít understand how these probes work.
If you are using the G3X system with the GEA 24 and capacitance probes like the Princeton or Westach, do you need a converter since the GEA allows a frequency input? What am I missing here?
Krea Ellis
Locust Grove, GA
Old 09-02-2021, 08:50 AM
Default probe
I cannot speak for the westach but my Princeton probes output 0-5v,not frequency, and are compatible with the GEA24, as is...no converter required.
You are also correct in that the Garmin system allows for either voltage or frequency...so there should be no converter required either way...
Bob
RV-10
N464RL
Old 09-02-2021, 09:02 AM
Krea,
There is a difference between the "probe" and the converter. The probe is a passive capacitor. In the case of the Vans kit is a set a plates. Princeton also makes (or did) make a probe which is really just the sensor. The probe then needs to interface to some electronics to make either a frequency or a voltage that can be measured. So some sort of electronic converter is needed before it can be connected to the the GEA module.
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
Old 09-02-2021, 09:14 AM
Originally Posted by rapid_ascent View Post
Krea,
Sorry, but those probes, not the plates, are not just passive capacitors...the electronics are built into the mounting puck.
The Princeton probes require NO converter, as they output 0-5v...go ahead and check the installation manual and FAQs on their website.
http://www.northwing.com/Princeton-F...bes-Manual.pdf
https://www.princeton-electronics.co...questions.html
The converter is only required if using vans plates, which are just that...plates.
Bob
RV-10
N464RL
