  #1941
Old 09-17-2021, 12:52 AM
Janekom's Avatar
Janekom Janekom is offline
Well done Pete. Now for the first flight report
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2021 WITH A SMILE
Old 09-17-2021, 09:17 AM
sahrens's Avatar
sahrens sahrens is offline
Default Congratulations
Itís a great feeling to be done.
Scott
RV-7 N818BG (flying)
Bearhawk Patrol (building)
Old 10-03-2021, 12:32 PM
mfleming's Avatar
mfleming mfleming is offline
Talking Visual Progress
This was a big week for 6RM.
On the gear and the engine hung...
I'm really excited about pushing forward.
Click image for larger version
ID:	16613  Click image for larger version
ID:	16614  Click image for larger version
ID:	16615  Click image for larger version
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring and Avionics harness completed 9/2/2021
FWF Started 9/3/2021
Donated for 2021 and so should you
Old 10-03-2021, 02:10 PM
wirejock's Avatar
wirejock wirejock is online now
Default Engine
Congratulations! Engine is on.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 10-04-2021, 07:02 AM
Mnemonics's Avatar
Mnemonics Mnemonics is offline
Default First Engine Start: RV-7 / ULPower 520iSA
https://www.youtube.com/watch?v=r6NcLM3dA1Y&t=152s
Marcel Heijmans
RV-7 PH-MNX (reserved)
Blog ph-mnx.nl
Vlog YouTube: PH-MNX
Builder# 74668
Member NVAV
Old 10-04-2021, 05:19 PM
skydiverlv skydiverlv is offline
Originally Posted by Mnemonics View Post
Sweet! And smooth.
Larry Vandegrift
ULPower 260is
Old 10-15-2021, 09:06 AM
motodave motodave is offline
After fighting with designing a mold (and tweaking it) and fabricating my custom plenum to fit my James cowl for over a month it's finally at state I will call done for now other than a slight trimming of the intakes. I will end up with some sort of very thin gasket on the edges and still need to go around the engine seal with RTV or similar to close all the small gaps between baffles and engine. Tip, if you can buy a plenum do it (I could not), making your own is a ton of work and still pretty darn expensive.
Details: I have 2 layers of 8oz FG on top of a Soric layer and then on the inside a layer of carbon fiber ($) for the body of the plenum. The intakes are multiple layers FG and then a ring of CF on the intakes. I used Fiberglast high temp industrial epoxy as I was concerned about heat soak on shut done. Nut plates are riveted to the inside with SS screws and fiber washer, holes in baffles are slightly oversize to allow some give with temp and engine vibrations. The plenum is pretty light 2-3lbs and very stiff.
I hope it works for me.
[url=https://flic.kr/p/2mANGry]
Dave
RV7 Slider N732DH reserved
I(O)360-M1B Thunderbolt
Empennage 100% Complete
Slow build Fuselage 95% done
Wiring 40% done
Was QB wings now will be slow build...
Littleton, CO
Photo log: https://flic.kr/ps/9jjZz
Old 10-15-2021, 10:32 AM
wirejock's Avatar
Default Plenum
Beautiful work Dave.
Please keep posting. I'm following because I have an RV Bits plenum to install. Looking forward to seeing how you join the ducts to the inlets.
Larry Larson
Estes Park, CO
Disclaimer
Old 10-15-2021, 10:41 AM
Thanks! I have some neoprene (wet suit material) I will use, tough and very flexible, this is what James recommends. A buddy has used neoprene on his "7" with a James cowl with good results. I was considering using SCAT but too ridged given the short span and sizing didn't work well.
FYI what I learned from this experience is: "friends don't let friends build fiberglass airplanes!" :-)
Dave
Wiring 40% done
Littleton, CO
Old Yesterday, 07:19 PM
ryankhallcpa@yahoo.com ryankhallcpa@yahoo.com is offline
Default Baffling work
Baffling work is not much fun.
Next up is fitting the snorkel.
btw...I reserved an N number last week. N789YZ Nothin special; I just wanted it to sound good and be easy to say.
Ryan
Taylor, AZ (KTYL); Builder #74649
RV7 N789YZ (reserved) - Emp done; SB Wings done; SB Fuse done; FWF in progress
XIO-360-M1B 9.0:1 pistons; built by JB Aircraft Engines
67 Cherokee 180C - Flying
USAFA - Son (class of 2022)
Donated Q1, 2021
My flight bag is made by Dewalt!
