  #11
Old 10-04-2021, 01:43 PM
AlpineYoda AlpineYoda is offline
Thanks Kyle and Richard for the answers.
I have a small problem with riveting these holes, though. My fuselage was a QB and the holes are not dimpled. I also have no way of knowing if the longerons behind the holes are countersunk.
Dimpling the holes in place using a rivet puller and a pull die is not possible, since I can't dimple with a longeron or other thick piece in place, and trying to dimple two things at the same time for the other rivets likely requires more force than a pull dimple die will be able to administer.
So, how do you rivet these? I could drill them to #30 and pull LP4-3s in each hole, but I would have a few ugly bumps along the skin.
RV-10 build blog -- https://eaabuilderslog.org/?blproject&proj=7ZSwfzr2g
Started 12/19/2019
Engine hung 1/9/2021
Panel hopefully coming fall 2021
N1814T reserved with FAA
Donated Jan 11 for 2021, EAA and AOPA member
Old 10-04-2021, 02:38 PM
Richard Connell Richard Connell is offline
I think you’d be able to tell whether the longeron was countersunk under a non-dimpled hole by closely inspecting it.
Id say it’s unlikely that’s the case (but not impossible).
If this is the case then I’d get in touch with Vans for a solution.
Otherwise id leave the hole at #40 and machine countersink the 032 skin and put an AD3 rivet in there.
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 10-04-2021, 02:59 PM
Kyle Boatright Kyle Boatright is online now
I think I countersunk and used standard 3/32 rivets.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 10-04-2021, 03:18 PM
Thanks for the advice - I will give countersinking a try.
Started 12/19/2019
