Old 10-05-2021, 10:12 AM
Glen P Glen P is offline
Originally Posted by kearney View Post
It is only when they are challenged by appeal to TC that they back down.
I’d be interested to hear whether this goes as smoothly as it should. I think you mentioned elsewhere that you weren’t installing a whiskey compass. Did I get that right? Do you anticipate that being an issue with MD-RA?
Glen Palmer
Toronto, Ontario
Working on -7 avionics/wiring
Dues paid July 2021
Old 10-05-2021, 08:24 PM
kearney kearney is offline
Hi Glen
Whisky compass is not an issue if you have a G5X or something equivalent.
That was resolved in my last inspection (2019) although some inspectors are unaware of the rule change. Quote the document on the MD-RA website if you have an issue.
The key for builders is to know the rules as well as the inspectors. They have to play by the rules just as builders do.
Les
RV10 C-GCWZ Sold and now vacationing in Tulsa
RV10 C-GROK Flying
RV10 # 3 - under construction
*** Dues Paid ***
Old 10-06-2021, 02:44 AM
pilotpat pilotpat is offline
I searched the MDRA website regarding requiring a compass, found only the final inspection checklist (part 6.6 1 requiring an "Independent Mechanical Compass"). During the close-out inspection last year the inspector said that the compass was required. Could you please supply a link detailing the requirements supporting a final inspection without one?
Old 10-06-2021, 06:21 AM
rv8bldr's Avatar
rv8bldr rv8bldr is offline
Yes, please, Les, if you could point us at that document that would be great. I am installing systems (including the panel) this winter and haven't figured out the whiskey compass thing. It would be nice if I didn't have to. Like most folks, when I fly I have multiple digital compasses available (phone running FltPlnGo, mounted tablet running FltPlnGo, and the new aircraft will have a G5, two G3X Touch displays all with battery backup and a secondary alternator).
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Flying a '79 Maule M5-235C
President EAA 245 Ottawa, ON
Old 10-06-2021, 06:34 AM
riseric's Avatar
riseric riseric is offline
Default C18E
Drifting from the gascolator issue but in line from how MD-RA and TCCA interpret the regs.
MD-RA form C18E, page 3:
Below are the applicable paragraphs from the Canadian Aviation Regulation.
Part VI - General Operating and Flight Rules Division II — Aircraft Equipment Requirements Power-driven Aircraft — Day VFR 605.14
No person shall conduct a take-off in a power-driven aircraft for the purpose of day VFR flight unless it is equipped with (d) a magnetic compass or a magnetic direction indicator that operates independently of the aircraft electrical generating system;
Note the word "or" between magnetic compass and magnetic direction indicator.
Refer to definitions on page 2 on the same document.
Eric,
2021 dues happily donated
RV-8 slow built #83274
Grove Airfoiled Gear, Wheels & Brakes
VPX-Pro, EFII System 32, EarthX batteries
Aerosport IO-375, MTV-9-B/183
Skyview HDX
C-GEMQ
Final inspection done!! Waiting for CofA
C-72R Cutlass, flying
Old 10-06-2021, 07:27 AM
Snowflake's Avatar
This is a perfect example of the MD-RA applying their (incorrect) interpretation and not the regulation.
Rob Prior
Old 10-07-2021, 05:10 AM
Default MD-RA Final Inspection with "magnetic direction indicator" vs "magnetic compass"
Can anyone supply installation details where MD-RA (or TC after resolution) accepted a final inspection where there was a "magnetic direction indicator" rather than a mechanical compass? Those details would help.
Old 10-07-2021, 07:54 AM
Snowflake's Avatar
Les (user Kearney above) passed an inspection that way.
Rob Prior
Old 10-08-2021, 05:16 PM
Hi
Both my RV10 builds were passed without a whisky compass. Below is an email that I received from Al Mahon, the president of MD-RA.
See document C70E on the MD-RA website - it is referenced in the email.
Sent: July 21, 2021 8:53 AM
To:
Cc:
Subject: RE: Inspection deficiencies - whiskey compass requirement
Les,
If in fact we have a delegate who isn’t aware of the EFIS compass requirement, I would only recommend you educate the RV-8 builder by forwarding the two Information/Guidance letters I provided in my response to you.
For warned it for armed!
Allan
Sent from Mail for Windows 10
Sent: July 21, 2021 10:01 AM
To: 'Allan Mahon'
Cc:
Hi Al
Thank you for the response.
To keep things simple, I'll focus on just the whiskey compass issue in this email.
Understanding that a Garmin G5X with a 4 hour internal backup battery meets & exceeds the C70E requirements (independent etc.),
1. What is the recourse of a builder who is told by their inspector that they MUST install a whiskey compass even though they have met the requirements of C70E?
2. Given this instruction, how does a builder handle this so that their CoA is not delayed?
You may recall, I went through this argument when my RV10 was inspected in 2019 and was told quite explicitly that I MUST install a whiskey compass. It took more than a little effort on my part to get this resolved.
Cheers
Les
Les
RV10 C-GROK Flying
*** Dues Paid ***
